Pacific Alaska, California, Hawaii, Oregon and Washington
How to install an aftermarket tach?
Old May 7, 2003 | 03:26 AM
ollie-99's Avatar
How do u install an aftermarket tach w/ a shift light?
Old May 7, 2003 | 04:46 AM
blue 79 Z/28's Avatar
read the instructions! lol j/k
Old May 7, 2003 | 12:32 PM
JD30thZ28's Avatar
The only wire you may have some problem with is the Tach signal. If you are using an Aftermarket ignition then you can just plug into the Tach Output but if your igntion system is stock then just splice into the green wire off the coil Aside from that follow the instructions.
mr28
Apr 20, 2016 05:44 PM
warmeck
Mar 22, 2015 10:28 AM
ldtantlinger92
Jan 19, 2015 01:26 PM
Rich_z28
Aug 27, 2002 12:20 AM
Snake Slayer
Jul 29, 2002 12:39 PM
