Horsepower Calculator
@ sea level sure they can run those times... but not at close to 4000 ft altitude
but yes, i'm eager to run at mission... but I can't afford to fix the car if it breaks at the moment (wedding to save for, etc...) so i've been putting it off and off and off... but eventually i'll get out there!
jeff
jeff
Originally posted by JD30thZ28
I guess it doesn't work for people who can't drive
I guess the only true measure is the good ol' dyno
I've never weighed my car nor have I ever got a 1/4 mile time - so I had to guess..........I think this may be fairly accurate.
Wow!
I thought it would come in around 6000HP!
I'm pretty happy with the results.
Horsepower Results - 1/4 Mile Method
Your Camaro Z28 weighs about 52904 pounds and can complete a 1/4 mile in about 11.03 seconds. That means that you've got about 7792.01 HP at the wheels, and about 10129.62 HP at the flywheel.
I thought it would come in around 6000HP!I'm pretty happy with the results.
This one you guys are using is not as good as this one IMO. Check this out.
Duane
www.prestage.com
Go under car math.
you can calulate almost anything!
Duane
www.prestage.com
Go under car math.
You can't go by the 1/4 mile ET since you have no traction etc.. MPH would tell a lil better. This one works better as you will see.
According to my cutlass CRATE engine which advertises at 345 wheel hp this is pretty bang on.
MPH of 110 with a car that weighs 3350 it shows a calculated hp of 348!!!
Not trying to rob thread
Duane
Duane
According to my Supra results I should have around 510 Wheel.
I dynoed that car at 450 before but gained almost 6 mph since the dyno so maybe it would be close to that.
New set-up now anyway!!
Duane
EDIT: Erik > yours shows you would be around 344 but hey. We have to do the timing and a few adjustments for next year anyhow
Low to mid 12's for you I hope for next year!
Duane
well if thats 330+ rwhp what mine came out as its BS cuz i only got 300hp max rwhp and it only dynoed in at 375hp exact same combo with open header, when i run at the track its through the exhaust. these programs are hokey
390 RWHP for my weight at 110mph trap speed
379 RWHP for my 12.50 ET.
Dunno I guess I will see when I get it on a dyno and tune it in a couple of weeks.
Times in sig I weighed 3650, calc says 413 RWHP for those figures
Ken
Re: Dunno....
Originally posted by kcsoz20
HHMMMM....According to this calc. with my best run this year on BFG drag radials and weighing, conservatively, approx. 3750#'s, after rollbar, SFC's, and Spohn torque arm, 12.50@110 it works out to
Ken
Ken
This one works great eh!
Duane
Nayr
Mar 3, 2023 08:34 PM
Aug 24, 2015 06:41 AM
