HELP...please
...just when things were going well..I ran into an issue...I was finishing up on the motor..torquing everything and making sure all is good...I double checked the intake bolts...torquing to 20 foot pounds....then a bolt broke..so now the intake is off it's fine..but now I need a tap and die set ASAP..please and thank you
Originally posted by LT1Z28
have a tap and die set however not sure if i have the right size
if you can figure out what bolt you have i will take a look and see if i got what yah need
later
Mike
later
Mike
M6= 6mm
1.0 = thread pitch
...does that mean anything to you? thanks Mike
..thanks Johnny
Got it if you need it Mike just give johnny a call and tell him to swing by i will be home all night
Later
Mike
Later
Mike
Originally posted by Camaro ChriSS
Damn. Tough break Mike. Glad Mike and Johnny were so helpful.
I broke the bolt for my TB one time. I thought it said ft-lbs but it was actually INCH-lbs! Nuts. Sheered the head right off.
Originally posted by sleeperZragtop
...yea alot of these guys are great...that's why I have no problem doing favor's...as for these LS1 bolts..we have to be very careful..these intake bolts are super weak and skinny
But good to hear you're almost done
M6 X 1.0 X 21.8
M6= 6mm
1.0 = thread pitch
..thanks Johnny
M6 X 1.0 X 21.8
M6= 6mm
1.0 = thread pitch
..thanks Johnny
If you can't get everything back in shape, I'd be happy to take it into work and throw it on the manual mill. If all ya need is a tap, let me know and I'll lend you one.
Originally posted by Erik
The diameter of the bolt is 6mm (actually, slightly less) and there is 1 thread every millimeter. The tap drill size is 5mm. To determine the tap drill size for metric threads, subtract the pitch from the diameter.
..so this point I don't know
Where is your bro
I have the Camaro finally
