Pacific Alaska, California, Hawaii, Oregon and Washington
HELP...please
Old Mar 24, 2003 | 05:15 PM
sleeperZragtop's Avatar
Unhappy HELP...please
...just when things were going well..I ran into an issue...I was finishing up on the motor..torquing everything and making sure all is good...I double checked the intake bolts...torquing to 20 foot pounds....then a bolt broke..so now the intake is off it's fine..but now I need a tap and die set ASAP..please and thank you
Old Mar 24, 2003 | 05:32 PM
LT1Z28's Avatar
have a tap and die set however not sure if i have the right size
if you can figure out what bolt you have i will take a look and see if i got what yah need
later
Mike
Old Mar 24, 2003 | 05:41 PM
JD30thZ28's Avatar
If you need me to grab the stuff from Mike's on the way home I can do so
Old Mar 24, 2003 | 05:53 PM
later
Mike
M6 X 1.0 X 21.8
M6= 6mm
1.0 = thread pitch
...does that mean anything to you? thanks Mike
..thanks Johnny
Old Mar 24, 2003 | 05:57 PM
JD30thZ28's Avatar
Give me a call on my cell or at work if you need me to pick it up
604-306-3028 (cell)
604-730-3057 (wrk)
Old Mar 24, 2003 | 06:14 PM
LT1Z28's Avatar
Got it if you need it Mike just give johnny a call and tell him to swing by i will be home all night
Later
Mike
Old Mar 24, 2003 | 06:21 PM
Later
Mike
..thanks Mike..I'll have it back to you asap
Old Mar 24, 2003 | 06:27 PM
JD30thZ28's Avatar
Mike S I will at your place around 6 or so I will call your cell Where is your bro I have the Camaro finally
Old Mar 24, 2003 | 07:02 PM
Camaro ChriSS's Avatar
Damn. Tough break Mike. Glad Mike and Johnny were so helpful.
I broke the bolt for my TB one time. I thought it said ft-lbs but it was actually INCH-lbs! Nuts. Sheered the head right off.
Old Mar 24, 2003 | 07:08 PM
LT1Z28's Avatar
Hey mike give me a call.
319 4252
Old Mar 24, 2003 | 07:58 PM
...yea alot of these guys are great...that's why I have no problem doing favor's...as for these LS1 bolts..we have to be very careful..these intake bolts are super weak and skinny
Old Mar 24, 2003 | 08:36 PM
Muskys SS's Avatar
Yeah, I was going to ask how did it break with only 20ft/lbs of torque??? They must be fragile.
But good to hear you're almost done
Old Mar 24, 2003 | 08:48 PM
Erik's Avatar
Classic Tech Moderator
M6 X 1.0 X 21.8
M6= 6mm
1.0 = thread pitch
..thanks Johnny
The diameter of the bolt is 6mm (actually, slightly less) and there is 1 thread every millimeter. The tap drill size is 5mm. To determine the tap drill size for metric threads, subtract the pitch from the diameter.
If you can't get everything back in shape, I'd be happy to take it into work and throw it on the manual mill. If all ya need is a tap, let me know and I'll lend you one.
Old Mar 24, 2003 | 09:20 PM
Thanks Erik..Mike helped me out with the tools..it's all good now, but the issues now is that when I drilled out the old bolt, it fell through the head...now the thing is I don't know where the bolt is...in the oil pan, piston..not sure..I can't believe the intake bolt holes are drilled right through head, or are they ..so this point I don't know
Old Mar 24, 2003 | 11:44 PM
zturbo's Avatar
If you need a set of ls1 heads to swap out with if those are messed up i have a set on my work bench..Weldcome to them as they are for mock ups only.
Steven
