Pacific Alaska, California, Hawaii, Oregon and Washington
Headlamps Are Broken !!
Old Jun 7, 2003 | 01:01 AM
Tw!tchb!tch's Avatar
Angry Headlamps Are Broken !!
10 000 kms on this giant pile of **** and the headlamps dont work . The pass side goes down and starts making a horrible GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRR NOISE !! Im sOOOO Pissed off right now . It is SOOOOOO loud . What ****ty quality !!
Anybody know how to fix this ?? are the teath sripped ??
Now when I press my alarm button to arm or disarm the lights go up and down . . . they never did that before and the markers dont flash
Warranty time I guess already
Old Jun 7, 2003 | 01:04 AM
sideways_Into_3rd's Avatar
"sir due to the use of nitrous oxide, your warranty is VOiD"
baaahahahaha
thats why u should've bought a camaro no headlight motors to break
Old Jun 7, 2003 | 01:13 AM
93formula's Avatar
dude same with mine, but mines ten years old!
you just gotta take the motor apart and replace the gear in it. and the head lamps like to go up and down with the park lights because "the car lets you know" that something is wrong. thats what another member told me anyway.
fix the stripped gear and the up/down thing will go away.
http://www.bfranker.badz28.com/headlightfix/index.htm
there you go man fix er your self! unless you wanna go thru warranty. bu this way youll never have to change it agian. im gonna install these in my new front end motors before they go in.
Old Jun 7, 2003 | 01:29 AM
This is what makes me so pissed eh , took me one search and I got loads of people with exactly the same symptoms I think I will order the brass gears . Thanks GM !! I HATE THESE POPUP LIGHTS THEY SUCK !!
Thanks for the help guys
Old Jun 7, 2003 | 01:32 AM
Im not letting those turds anywhere near my car man !! Im going to take it all apart tomorow and see what I can do about making those peices of **** quiet too My cat could design a better setup with **** he digs up from the back yard
Old Jun 7, 2003 | 02:11 AM
LT1Z28's Avatar
hey twitch i just ordered my set they are here already. I only have one bad one but was going to change both if you want you can order a set of two and borrow one of mine till it gets here if it is pissing yah off that much.
Old Jun 7, 2003 | 02:20 AM
HELL YA !!!!! THat would kick *** !! Ill send U a Pm
Old Jun 7, 2003 | 03:20 AM
SBainsTA's Avatar
You know, the other thing you could do is to disable the "auto on" and then you have control of the motors and they don't get used as much. That's what I did and knock on wood theyre still ok. Also, the TA's look mean at night just rolling with the fog light s on. This way also the lights don;t go on in the garage and shut off when you roll out. You have complete control of them. Takes about 6.21463 minutes to do and costs..... .0000001 cents.
If you want to know how let me know. It's easy
Old Jun 7, 2003 | 03:52 AM
Rybar's Avatar
I was wondering how to do that? Can you enlighten me?
Old Jun 7, 2003 | 04:07 AM
nitrous is THE SHHHHHHHHHHHHHIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII IIIIIIIIIIIIIIIIIIIIIT
Old Jun 7, 2003 | 09:10 AM
I did that mod right away when I got the car , daytime running lamps are queer I just sautered two terminals together in that little black box behind the hvac controlls and it worked like a charm . There is a write up over on ls1.com if anyone hasnt done it yet . . . I hated the auto lights .
I actually think the damage was done when someone tried yanking the lights up and made them all sloppy
Payam your ****ing nutz !! How is she on the street . . . . a little more power for passing he he
Old Jun 7, 2003 | 02:11 PM
Did the free fix , worked like a charm . Hardest part was aligning up all the gaps afterwards . Yay for my Transam WooHoo !!
Old Jun 7, 2003 | 02:26 PM
SBainsTA's Avatar
Sure.... If you were to look at the top of your dash, you should see that little round opening where the light sensor is. What you do is lift up on the panel on top of the dash, don't worry it'll com off with some firm pulling.
Reach inside and you'll see where there are two wires running to a "plug". Turn the plug and pull down. It has one of those twist locks, where it only comes off one way.
When you get it off, you will see what looks like a little flatheaded blue bulb. Pull it out. This is the sensor.
Then, if you smoke pull off the aluminum in the cigareete pack and burn off the paper. Or of course you can go get some aluminum foil from the kitchen.. You only need enough to shove into the plug where the sensor used to be.
Once it's in, make sure that the connections via the aluminim foil are together. If they are not, when you turn on the car in the daylight, the lights will automatically come on. If that happens, push the aluminum foil in farther.
Now you can either try to put the plug back in. Pain in the a$$ if you have big hands, or you can leave it as is. And your done. You now have complete control of your life and your lights!!
Hpe that helps!! Call me if you have any other questions. 604-808-5327
Oh yeah, Rybar, I haven't forgotten about your furniture store. When the time comes we'll talk. give me a few months.
Isn't that for the orange corner lights that come on? The mod that I'm talking about prevents the headlights from popping up when your driving and you go through a shady spot, etc
Old Jun 7, 2003 | 02:51 PM
My style car doesnt have the big circle in the dashboard , its got it somewhere else . You pull the hvac and locate a little black box and bust into it . Using the diagram ( Ill try to post that too ) you sauter two terminals together and walla , no auto headlamps . This works for my model year , Ill find the link
Old Jun 7, 2003 | 02:54 PM
This is the one I used
http://www.xse.com/leres/ss/drl.html
