Pacific Alaska, California, Hawaii, Oregon and Washington
Good news and bad...mostly good.:)
Old Mar 5, 2003 | 12:32 AM
97TA-WS6-Con's Avatar
THE BEAST HAS AWOKEN
although its a grumpy SOB.
I tried to start the car a couple of days ago and had spark problems.
With the help of Cory (again, what a great guy) we found a blown fuse and based on a nagging worry, I relocated a wire that I had connected to the wrong spot. I put in a new fuse and
It awoke.
Rashpaul had come over just as Cory and I were buttoning things up and he was here to get the car running on the FAST.
THAT is the good news. The "bad" news is that it did not want to stay running. Though it ran for a good 5 - 7 mins we could not get it to start a second time and then it got to late to keep trying anyway.
We also found that the WB O2 sensor does not seem to be working so I have to speak to FAST about that but I cannot say how happy I am that at least it ran for a while. I only hope that the issue right now is minor.
Should be ready to bolt the wheels on soon.
Yippeeeeeeeee.
Old Mar 5, 2003 | 12:39 AM
sleeperZragtop's Avatar
Nice work Shawn ....it's my turn next, then Mike's....
Old Mar 5, 2003 | 12:50 AM
kal2k's Avatar
cant wait to see it at the next meet
Old Mar 5, 2003 | 03:34 AM
sideways_Into_3rd's Avatar
like i explained in that email shaun even if u get 'er running .. she wont stay running for long with ur TPS reading wrong
FIX THAT TPS MAN ...
congrats .. i would've liked to be there for the fire up .. i wish we would've tried to troubleshoot that fuse last night further
anyways .. give me a call when its time to tinker with FAST
and ask rash about those individual timing retards i fixed in ur tune .. u had upto 57 degrees of retard in one of ur cyl's
Old Mar 5, 2003 | 03:53 AM
LuCiFeR97Z28's Avatar
Thumbs up
Congrats Shaun, sounds like you have made some great progress .
A.
Old Mar 5, 2003 | 10:36 AM
Camaro ChriSS's Avatar
Thumbs up
Wow Shaun... that beast is a labour to produce! Can't wait to see the results though when its all finally brought together.
Kudos to Cory for his helping you. He's a good guy.
Old Mar 5, 2003 | 10:52 AM
JD30thZ28's Avatar
Thumbs up
Glad to hear you got it started Shaun You should have these little issues sorted in no time Can't wait to see it at Mission
Old Mar 5, 2003 | 11:42 AM
bunker's Avatar
congrats shaun !
Old Mar 5, 2003 | 12:19 PM
TopSpeedZ28's Avatar
Awesome news on the beast coming to life!! Someone needs to take some video of the monster going through it's progression so us Island inhabitors can see and hear the fire-breathing dragon as it rears it's sleeping head....
Old Mar 5, 2003 | 12:27 PM
Muskys SS's Avatar
Great news Shaun!!!
Good to hear you got her going. It should all be down hill for now. Good luck
Old Mar 5, 2003 | 12:38 PM
Actually the car was running quite well after a sluggish start. We had to feather the pedal to get it started but once it warmed up it was ideling very comfortably on its own. It ran for 5 mins all on its own.
However, when we shut it off we had trouble getting it started a second time.
Also Payam, I said to Rash that we needed to calibrate the TPS. His response was that at idle it would hover at 15% and at WOT it would be 85 - 90%. I did not even OFFER that we had seen that ourselves. It seems an idiosincracy (sic) of FAST but I will be asking them that very question to confirm.
Old Mar 5, 2003 | 12:57 PM
well .. if FAST thinks ur TPS is 15% .. but ur TB blades are closed as ur ideling .. it will put in a LOT more fuel as needed for idle and make ur car run PIG RICH ... i doubted that ur car would even idle that rich .. i guess i was wrong ... but either way .. that TPS needs to read from 0% to 100% .. not 15% to 88%
Old Mar 5, 2003 | 01:51 PM
well FAST said the same thing as Rash.
Me: Should my TPS results not read from 0% - 100%.
FAST: No Sir, they will usually read 15 - 18 % on the idle to 86 - 90% at WOT.
Me: Is that any kind of problem.
FAST: No sir. Not at all.
*shrug*
Old Mar 5, 2003 | 01:59 PM
*shrug* x 2
Old Mar 5, 2003 | 02:12 PM
JD30thZ28's Avatar
Question
15%-90% TPS readings
