Pacific Alaska, California, Hawaii, Oregon and Washington
Dyno Results.....
Old Oct 23, 2003 | 08:41 PM
kcsoz20's Avatar
Thumbs up Dyno Results.....
spent some time dynotuning the Z today.
Started off with a baseline pull of 331 rwhp with a 14.5 AF
Ended with a 365 rwhp 330 tq with a 12.3-5 AF.
The car was falling on its face at 6000 rpm. The torque curve was flat all the way through the pull and the HP was still climbing but I could not get past 6000 rpm. The car felt like it hit a wall!!! I was actually feeling it fall on its face the last few times I had it at the track. Even at the track it was only falling on its face in high gear running through the traps or just before.
I have changed the plugs recently but did not change the wires.
I believe and Sean believes there is more in the car if we can just get past the high RPM stumble. I can see at least 380 RWHP if I can get it up to 6500+ RPM.
We did not even play with timing just got the AF set right.
Ken
Old Oct 23, 2003 | 09:16 PM
bunker's Avatar
what are your mods?
Old Oct 23, 2003 | 09:20 PM
OneFlyn95z28's Avatar
This is real common with the XE cams. I would check the valve springs. then I would check the opti
Not bad numbers man!
Old Oct 23, 2003 | 09:35 PM
kcsoz20's Avatar
Lightbulb
Short list of mods:
Heads by Dave Endrigo, XE 230/236, Meziere electric H2O pump, jet hot LT's, 1.6 RR's, 2800 stall Vig, Strange 3.73 gears, etc,etc.
Ellis The Opti was new when I built the motor *shrug* I think I will start the easy way, first checking wires to include coil wire and coil. Coil is original. Search and hunt I guess.
Ken
Old Oct 23, 2003 | 11:00 PM
bunker's Avatar
you need atleast my cam to hit 6500 any lower & you hit the wall at 6k, that is because your cam is acctually the size of a hotcam durring ramp up/ramp down stages, look at the .006 lift & compare it to a hotcam, they are almost identical, except hotcam i belive is bigger on the exhaust at .006 lift.
Old Oct 24, 2003 | 12:25 AM
Pandamonkey's Avatar
365! Wow........that's pretty fantastic.......
Its a WHOLE Honda Civic more than my Camaro...........
Congrats man! I'm jealous.
Hope you reach what you want.
Old Oct 24, 2003 | 12:39 AM
93TAWicked1's Avatar
Dude those are nice numbers I'm suprised at the increase can't wait for you to get it back at the track!!!! I really wanted to make it the damn dealer had my car, I wanted to talk to them about LS1 edit!
Congrats can't wait to see the times that was ALOT of HP to give up to bad tuning!!!
Bobby
Old Oct 24, 2003 | 01:00 AM
NiteRider's Avatar
Your not going to hit 6500 with that cam, nore do you want to.
Old Oct 24, 2003 | 02:58 AM
bunker's Avatar
Hey I hit 376.5 & 350tq with problems noone says congrats to me improvements are under way, almost ready for next dyno day with a tottally new setup.
Old Oct 24, 2003 | 11:01 AM
spo/z mike's Avatar
right on Ken
Old Oct 24, 2003 | 11:18 AM
JD30thZ28's Avatar
Nice numbers Ken. I think you can find some more HP in there
Old Oct 24, 2003 | 01:54 PM
bunker's Avatar
bastards
Old Oct 24, 2003 | 02:10 PM
sideways_Into_3rd's Avatar
ok crybaby
congradoolations on ur lame *** 376.5 rwhp
now slap them heads on and lets shoot for 400+
Old Oct 24, 2003 | 02:13 PM
kcsoz20's Avatar
Thumbs up
Thanks all.
Hey Bunker, nice numbers man!!
Ken
Old Oct 25, 2003 | 02:58 AM
bunker's Avatar
Ohh you'll see 400+
