Pacific Alaska, California, Hawaii, Oregon and Washington
Disabling DRL and Auto Headlights
Old Mar 30, 2004 | 02:59 PM
Amit's Avatar
found a good how too on this..
im pretty sh¡tty with wires and electrical so this is a big help.
Disabling the Day Running lights and the Auto Headlight on feature is quite an easy mod and can be reversed just as easy. This mod takes approx. 10 min. and all the tools needed are a socket set.
1. Lift the trim plate from around the radio and climate control panel. No tools are needed as it is held on by pressure clips. Set it aside.
2. Take out the four hex screws holding in the radio in. (Note) You don’t need to disconnect the battery for this operation BUT if you do, make sure you know the code for your radio if it is enabled. You will need it to ensure your radio operates after putting it back in.
3. Move the radio aside and look into the dash. In the upper right corner on the firewall you will see a small black box with two wire harnesses attached to it (about the size of a pack of camels).
4. Lift the box in an upward motion, it’s on a slide clip. Bring the box out of the dash, there is plenty of wire to manage easily. Disconnect the wire harness with the BLUE wire in it, just let it hang out of the way. THAT’S IT!
5. Re-install the wire box, radio and faceplate.
im gonna do this tommorw.
Old Mar 30, 2004 | 07:02 PM
Tw!tchb!tch's Avatar
I can do the mod for you when we put your halos in . I do it the oem way by soldering the terminals inside that little black box . The us models have this done from the factory . Auto headlamps lick nutz
Edit: Fixed horrible spelling
Old Mar 30, 2004 | 07:50 PM
Amit's Avatar
yeah but i also want the ability to change it back if need be.. afterall disabling drl's is illegal.
Old Mar 31, 2004 | 10:58 AM
Black Robe's Avatar
I pulled the connector from the daylight sensor (next to the alarm LED) and put a small 'U' shaped .040" lockwire jumper across the terminals of the connector, then taped the connector out of the way. This disables the auto HL but leaves the DRLs intact. [No soldering required]
Old Mar 31, 2004 | 11:46 AM
richy rich's Avatar
Thumbs up
Hey guys thought I would share my 2 cents on going about this drl problem.As you all know the gm cars have a littlr eye like on the top of the dash right?Well I pulled mine up from the top-no need to break out any tools,just grab it with your fingers & pull up.Then when it comes up it will have 2 wires attached to it.Undo the lense cover[plastic piecs you see from top of dash],it seperates from that little blue light pu thing by simply giving it a turn[like a turn signal bulb]Dont lett the 2 wires fall back in the "hole".Now open up the hole of the plastic lense cover w a drill or small file-about double the size as how it was,so now the drl are way less sensitive,but they still come on at dark[cause the hole 's bigger it lets in more light to the sensor]Ive done this on all my late model Camaro's & Vetts & it's the shat!
Old Apr 1, 2004 | 02:53 PM
camaro322hp's Avatar
Re: Disabling DRL and Auto Headlights
i've done this. there is one small drawback to this method: the ignition has to be off in order to pop the rear hatch. this is a result of the BRAKE light being disabled after this mod. so, since the car does not know that the parking brake is set, it won't let you pop the hatch until the car is turned off.
Old Apr 1, 2004 | 09:54 PM
93formula's Avatar
the thing i dont get is, why do your camaro guys care wether or not you have auto head lights? its not like you have your headlights pop up annoyingly like the bird ones. you wont even know that there on. and personally i love the way the f bodies look with the yellow drls from far away.
Old Apr 2, 2004 | 11:25 AM
SBainsTA's Avatar
i've always wondered the same thing myself
Old Apr 2, 2004 | 09:49 PM
93formula's Avatar
come on now, i want to hear a decent explanation.
Old Apr 3, 2004 | 12:11 AM
Amit's Avatar
i want to get rid of the drl's cause it looks tacky, imo.
i want to get rid of the auto headlight cause when i get my halos installed i can have it on with just the foglights and parkign lights..
and not the headlights. obviously when it gets dark i will use the headlights.. but when its not THAT dark i can have just my halos on. the auto headlight function seems to be pretty sensitive.
get it?
Old Apr 3, 2004 | 12:24 AM
93formula's Avatar
so you bought these "halo" light to only use them during the 'dusk' hours. i see.
well what about the rest of you camaro auto headlight disablers?
Old Apr 3, 2004 | 12:32 AM
Amit's Avatar
i bought the halos cause they look fxckin killer!
Aug 17, 2015 09:50 AM
Aug 7, 2015 08:52 AM
MichiganSkip
Aug 6, 2015 09:38 AM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
