Pacific Alaska, California, Hawaii, Oregon and Washington
Compression test results
Old Mar 24, 2003 | 10:58 PM
raene's Avatar
Thumbs up Compression test results
Just got the compression test results on my brother's hybrid Civic. The engine's a 14-year old motor from Japan, running 10.2:1 compression. The results are as follows...
Cyl #....4......3......2......1
Test1:232..220..228..217
Test2:233..222..228..223
What do you guys think? Mine's tested at 210-220psi across the board. Bastard, I'm kinda jealous
Old Mar 25, 2003 | 12:10 AM
Draco's Avatar
Looks pretty good for a 14 year old motor! less then 10% variance across all cylinders is a good sign for a motor that old
Old Mar 25, 2003 | 12:20 AM
bunker's Avatar
Do a HOT compression test, that will tell you a much better story, comparing COLD & HOT compression tests will tell the story for each cylinder as to what their next plans are
Old Mar 25, 2003 | 01:52 AM
raene's Avatar
Those are hot results, yes
KYWes
Jun 14, 2022 06:52 AM
asilomar244
Jul 12, 2015 05:53 AM
surreybrad
Jul 5, 2015 10:36 PM
SergheiS
Jul 5, 2015 03:27 AM
