Pacific Alaska, California, Hawaii, Oregon and Washington
Clicking Noise from suspension
Old Apr 1, 2004 | 06:52 PM
JD30thZ28's Avatar
Hey guys i know this is hard thing to solve but just thought you may have some ideas or personal experiences. I am hearing a clicking noise when i go over bumps and when i take left turns. It is from the passenger side, it only happens on some bumps but whenever i turn left it is there. Any ideas?
Old Apr 1, 2004 | 09:13 PM
CoryM's Avatar
Swaybar comes to mind. It could also be anything else so you will have to take the wheel off and have a look for anything worn or sloppy.
Old Apr 1, 2004 | 09:49 PM
93formula's Avatar
click or clunk? click click click or just one clunk? could be the lcas, are they the rod end ones? loose exhuast? go under and see if all the ehxuast hangers are on tight. could the sound be coming from the wheel area?
Old Apr 1, 2004 | 11:46 PM
StreamlineZ28's Avatar
look for a rock in your tire
Old Apr 1, 2004 | 11:48 PM
Killaz's Avatar
I ASKED THIS QUESTION LAST WEEK. pUT SOME GRESSE UNDER THE SPRINGS. rIGHT ON THE PIRTCH THAT THEY SIT ON. WORKED FOR ME.
hOLLA
Old Apr 2, 2004 | 12:08 AM
OneFlyn95z28's Avatar
I have had this on three cars.
On all of them it was the back Lower A arm bushings. They were worn and this lets the arm rub the K member and makes a clicking sound going over bump.
We used poly bushings for replacements. ONLY install the lowers!! Or trust me that click is nothing compared to the damn squeaking my upper arms make!
Not sure if this is what you are hearing but what I have found in the past. I hope this helps!
Old Apr 2, 2004 | 12:48 PM
JD30thZ28's Avatar
Wasn't the sway bar, that was my first guess, isn't the exhuast, it is coming from the front suspension, i will try that greese trick but I am now thinking it is the bushing for sure. Thanks Guys The sound is driving me crazy
Old Apr 2, 2004 | 01:40 PM
sideways_Into_3rd's Avatar
I had the exact same sound johnny .. i bet you its the spherical ends on the lower A arms ...
what happened with the K member fiasco ?
Old Apr 2, 2004 | 01:46 PM
JD30thZ28's Avatar
The spherical ends make a noise as well, that i can live with This is a louder clunk noise.
Old Apr 2, 2004 | 02:47 PM
I got a loud clunk noise since day 1 as well .. exactly the same one u speak of .. it was rare though .. speically when i was turning on a bump .. i lived with it
Old Apr 2, 2004 | 03:21 PM
JD30thZ28's Avatar
It is the back bushing on the lower control arm on the passenger side, the bushing is collapsed and broken at a point. So i am pretty certain that is where the noise is coming from Thanks Guys
Old Apr 4, 2004 | 12:43 AM
I had a feeling
lildemars09
May 28, 2015 07:54 PM
cmsmith
Apr 30, 2015 05:18 AM
jj71787
Dec 30, 2014 02:15 PM
HuJass
Aug 29, 2002 02:30 AM
HuJass
Aug 27, 2002 09:53 PM
