Can some one measure their stock pan hard bar for me...
Thanks ChriSS...no one wants to help me
...one more thing ChriSS, one your rad...the tranny cooling lines, which one is "in" and which one is "out"....I'm gonna install my cooler but I'm stumped
Yes, 43 inches.
Take the top line out of the rad (return line) and go into the cooler. Doesn't matter which side of the cooler - the fluid just flows through it. Then, come out of the cooler from the other hole (now your outlet) and mate it to the stock metal cylindrical tranny cooler line. Does that help? Drop me a PM if need be.
What I used as the inlet into the B&M cooler was if you hold the cooler so that the metal mounting flanges are on the bottom, and the two holes on the cooler are facing you, the one on the left was the inlet and the one on the right the return (outlet).
....is that 43" from the middle of both bolts...the adjustable BMR I installed is sitting at 38" and the rear end is sitting about an 1" too far on the driver's side...
Originally posted by BPS
43" from bolt hole to bolt hole on my old PHR
...thanks BPS..I'll do some digging in the morning..BTW..I have been checking your car out on the VIF-body site and I'd really like to see it..next time your on the mainland..pm me
