Pacific Alaska, California, Hawaii, Oregon and Washington
blue 79 Z28 gose 12s
Old Sep 21, 2003 | 03:23 AM
sleepybu's Avatar
Old Sep 21, 2003 | 03:25 AM
blue 79 Z/28's Avatar
well i did it, didnt really change anything but it hauls *** now, ran a 12.950@104.96mph 1.794 60' and an hour after that on my second run i did a 12.952@105.00mph 1.787 60' not bad, finally busted the 12 barrier and did it twice in a row!
Old Sep 21, 2003 | 01:37 PM
Zedzag's Avatar
2nd gens
hey Jason, what's your shift rpm?
Old Sep 21, 2003 | 01:50 PM
Tw!tchb!tch's Avatar
You BASTARD !!
Old Sep 21, 2003 | 02:02 PM
SBainsTA's Avatar
Good to hear!! Congradrulations bro!!!
Old Sep 21, 2003 | 02:21 PM
sideways_Into_3rd's Avatar
Rockn'
i could've definately hit a 12.8ish if i couldve reached the gas pedal all the way down .. but if feel that much better doing it urself congrats bud.
Old Sep 21, 2003 | 03:56 PM
Originally posted by Zedzag
2nd gens
he i ran a drag simulator and punched in all my specs and before i was shifting at 5900 and then the tranny would lag and actually shift at about 6200, well now i shift at 6100 and its not shifting till 6500!!! so im shifting effectvely at 6500rpm on a stock sbc and it likes it as you can tell hah
Old Sep 21, 2003 | 04:07 PM
bunker's Avatar
Congrats, I remember the day I broke into the 12's with lt4 hotcam 12.8@109.39 though & street tires but its was on an AUTO 93 Trans Am.
Congrats
Old Sep 21, 2003 | 04:25 PM
Zedzag's Avatar
Hmmm, I was shifting at 6500 but it was probably higher as well due to sloppy shifter cable and such. I'll try at 61-6200 and see if that helps me.
Old Sep 21, 2003 | 04:38 PM
ya, unless you got a full manual valve body, the auto retains its automatic features such as the second gear band etc. when your holding it in first and shift to second the band has to apply and dissingage to line up to second gear, cuz the low/reverse clutch drum and hight clutch drum are spining then the second gear clutches need to allign in this. if you got a full manual its a different operation going on in there and it hapeens instantly as soon as you move the lever. same as in "drive" mode to keep it simple, 2 less parts are moving inside so its auto lined up so the shifts are instantly, but if you shift manual 1-2 by hand in not a full manual tranny, you got to account for the delay factor of the shifting, thats why i set me shift light at around 6100 cuz its in gear by 6500rpm
p.s. this is th350 tech, other autos are similar but do certian things differently, results are similar but not exact
Old Sep 21, 2003 | 08:10 PM
LuCiFeR97Z28's Avatar
Congrats
I was there the first time you broke into the 12's...your time was 12.99 . I think you're referring to the second time .
Old Sep 21, 2003 | 10:51 PM
NiteRider's Avatar
Aly is right man, me and you have always argued about it, finally someone else remembers.
Old Sep 21, 2003 | 11:01 PM
Drumhawk's Avatar
way to go blue z28, 12's are great and something to be proud of.
Old Sep 21, 2003 | 11:04 PM
Erik's Avatar
Classic Tech Moderator
Gotta love 12 second, second gen Camros
OneFlyn95z28's Avatar
ABOUT TIME!
I will help you out on the shifting. Take and put heavier govenor springs in it. It will shift real soon when shifting automaticly but will make the shift quicker when you manualy shift as well
I remember my first 12 in my 74 Z28. It was 10 years ago now. 12.46@116 on M/T 28x12.5s 15s. With 4.56s it would hook hard and run the fuel bowls dry resulting in 1.9x 60ft times.
Good to see that thing running good!
