Pacific Alaska, California, Hawaii, Oregon and Washington
Bad day for the camaro
Old Sep 24, 2003 | 02:03 PM
  #16
Tw!tchb!tch's Avatar
Shut up and spray the b!tch
Old Sep 24, 2003 | 10:48 PM
  #17
LT1Z28's Avatar
The sound clip is still messing with my head. Its hard to say bbut from the clip i aint agreeing with the header gasket.
For starters he is running metal GM gaskets and it is damn hard to blow them apart as mush as required to make that much noise.
Secondly the sound is too tinny and rapid for my liking also. Like I said it could be just the speaker on the camera messing with me . But I would proceed with caution and make sure it actually is a header gasket and not something else. From what i hear it sounds more like a rocker or lifter gone completely south.
Also if it in turn was a eshaust leak of that magnitude you would more then likely not be questioning it. For starters you would be able to feel the air around the header blowing out and you would also be able to smell the exhaust under the hood. If you cant oliver then i would look deeper for the problem.
Take care
Later
Mike
Old Sep 24, 2003 | 10:55 PM
  #18
93formula's Avatar
if its a tick tick tick sound then its a lifter, oliver you can come listen to mine if you want.
Old Sep 24, 2003 | 11:19 PM
  #19
ollie-99's Avatar
yeah its a ticking noise
roy if u got msn add me
oliver98@Hotmail.com
Old Sep 24, 2003 | 11:22 PM
  #20
93formula's Avatar
i already have you on my msn
Old Sep 26, 2003 | 12:35 AM
  #21
ollie-99's Avatar
heres a link to the video
HERE
Old Sep 26, 2003 | 12:57 AM
  #22
bunker's Avatar
Ohh God you guys crack me up, every noise is distinct, you can't describe a noise to someone & expect to be able to tell, those I can guarrantee & knowing what many sounds sound like is not a lifter, its either a header/exhaust leak or blown headgasket out the side, one or the other.
Old Sep 26, 2003 | 01:00 AM
  #23
93formula's Avatar
thats pretty damn loud!
Old Sep 29, 2003 | 01:15 AM
  #24
bunker's Avatar
Ollie post a pic of that pushrod that was bent, & for those who though it was a lifter or something that sound was not a valve train sound it was an exhaust leak sound that was very loud, the pushrod bent so badly on the exhaust that it sat there doing nothing & the exhaust had no where to go so it came out of the intake & Throttle body/intake was all black obviously, so unless you have a muffler on your intake its gonna be loud
post pics
I said intake instead of exhaust accidently sounded stupid, so its edited
Old Sep 29, 2003 | 01:18 AM
  #25
ollie-99's Avatar
http://groups.msn.com/GMsFbody/car.m...to&PhotoID=848
http://groups.msn.com/GMsFbody/car.m...to&PhotoID=849
Old Sep 29, 2003 | 01:21 AM
  #26
mr_muff's Avatar
holy **** that is one ****ed up pushrod
Old Sep 29, 2003 | 01:27 AM
  #27
blue 79 Z/28's Avatar
that aint crap lol i can outdo that one!
Old Sep 29, 2003 | 01:31 AM
  #28
StreamlineZ28's Avatar
Originally posted by bunker
Ollie post a pic of that pushrod that was bent, & for those who though it was a lifter or something that sound was not a valve train sound it was an exhaust leak sound that was very loud, the pushrod bent so badly on the intake that it sat there doing nothing & the exhaust had no where to go so it came out of the intake & Throttle body/intake was all black obviously, so unless you have a muffler on your intake its gonna be loud
post pics
if that is a bent pushrod from the intake valve then how do you gget an exhaust leak. shouldnt the exhaust valve been working properly.
Old Sep 29, 2003 | 01:46 AM
  #29
bunker's Avatar
Oops I meant to say exhaust valve not intake valve , thats a pushrod from an exhaust valve, so there was no exhaust valve so when there was ignition it would come out the intake at times, other times it would either not ignite at all or spill the fuel back into the intake, most of the time it would ignite the mixture & then the exhaust had no where to go, & when the intake would open boom the exhaust is in the intake, read more carefully.
Old Sep 29, 2003 | 01:49 AM
  #30
bunker's Avatar
PS. if it was an intake valve which it wasn't, then you would still have problems because you'd have fuel in the intake.
Just so you know, but that would just case a split & rich mixture on other cylinders. But this one was the fourth pushrod from the front, which is an exhaust valve.
