Autocross - July 4th - Be there
I would not recommend mike , My 295's were perfect on a 10.5 . . . a now a little pinched on a 10" wide. I would put 315's on minimum 11" width to be optimal as your adding another 20mm's . You will end up pinching it down and bowing it up to the point where a 295 will have a better sidewall and overall contact area or youll have to run really low pressure to get it flatened out . . . in the end the 295 will feel tighter on a 10" wheel imo and save you some rotational mass .
