Pacific Alaska, California, Hawaii, Oregon and Washington
Anyone got a degree wheel and dial indicator?
Old Jul 3, 2003 | 12:41 AM
CoryM's Avatar
Hey guys, I need to figure out what cam I got so I am not wasting my $$ on the wrong valve springs. So if anyone has them I would like to borrow a degree wheel and dial indicator. I want to have this piggy back on the road so would like to order/buy the springs asap.
Thanks for any help guys.
CoryM
Old Jul 3, 2003 | 01:34 AM
bunker's Avatar
are you doing this with heads on or off?
PS. WHy don't you just put the cam straight up? unless you're planning on going perfect & choosing your own degree of advance/retard?
You don't need a degree wheel to figure out what springs you need man, what are you talkinga bout? all degree wheel will tell as far as cam goes is duration of the damb thing not lift. just use a vernier to measure your cam lobe lift & multiply it by your rocker ratio.
Old Jul 3, 2003 | 01:42 AM
bunker's Avatar
PS. whats the size of your base circle?
Old Jul 3, 2003 | 09:39 PM
CoryM's Avatar
So in other words, You dont have a dial indicator/degree wheel right Bunker? . Actually, have you ever heard of a thing called valvetrain harmonics? Im trying to avoid that. Also eyeballing it with a verneer is not nearly precise enough for me to get the best performance out of the valvetrain. Also I need to know exactly what this cam is so that I can plan the next one.
CoryM
Old Jul 3, 2003 | 10:22 PM
Erik's Avatar
Classic Tech Moderator
I've a couple of dial indicators... no mag base though.
Old Jul 3, 2003 | 10:25 PM
CoryM's Avatar
Thanks Eric. Ill just beg one from the shop. Just trying to use their tools less often .
Thanks again.
CoryM
Old Jul 4, 2003 | 05:29 PM
zturbo's Avatar
I am going to go see mikey this weekend i can bring my mag base and dial indicator with me if you need.
Steven
Old Jul 4, 2003 | 07:52 PM
CoryM's Avatar
Thanks for the offer Steven. I got it under control now. Hopefully will be up and running by tommorow evening.
CoryM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
FredM
Apr 10, 2015 02:56 PM
