Pacific Alaska, California, Hawaii, Oregon and Washington
.96 G's
Old Oct 16, 2004 | 04:19 PM
97TA-WS6-Con's Avatar
.96 G's
The V car has a lateral G meter in it - not sure how accurate it is.
So today coming off HWY 91 going on the 270 degree turn going right onto Hwy 10 the G meter hit .96.
The highest until now has been a very weak .82 going right and and even lamer .72 going left.
The car felt completely solid. No tire squeal - that I could hear above the Dirty Vegas CD anyway - and three is certainly a little more to go before hitting the limit. VERY fun experience I have to say.
Old Oct 16, 2004 | 05:17 PM
Pandamonkey's Avatar
Re: .96 G's
Damn man!
That's impressive! Not far off from a full G either.........I wonder if stickier tires would put it over the hump.
Like yourself Shuan - I also wonder about how accurate it is.
Assuming it's not too far off - or mabye none, I give you a
Old Oct 16, 2004 | 05:20 PM
Thump911's Avatar
Re: .96 G's
Top notch for even in the vicinity of that .96
Very impressive!
Old Oct 16, 2004 | 09:01 PM
CoryM's Avatar
Re: .96 G's
That will be peak lateral Gs. That is the little accelerometer measures how hard it gets thrown at it hardest. The skidpad testing is sustained lateral G forces where the accelerometer gets held out for a while. I would expect those cars to do mid to high 8s on the skidpad. Grab some pylons, a measuring tape, and a stopwatch and you can do your own skidpad tests.
The G-meter is cool though, I think it would be far too tempting to play with in everyday driving though for me .
Cheers.
Old Oct 16, 2004 | 11:04 PM
Amit's Avatar
Re: .96 G's
thats awesome!
my car with the slp suspenions is suppsed to pull .96 also. it prolly pulls more with my sts springs now.
who says our cars cant handle?
Old Oct 17, 2004 | 12:22 AM
Elgyn's Avatar
Re: .96 G's
Originally Posted by Amit
thats awesome!
stupid ricers
Old Oct 17, 2004 | 05:50 AM
bunker's Avatar
Re: .96 G's
lets put my G-tech in your car, it does the same thing, lets compare the accuracy, if they are both the same, then it must be accurate
Old Oct 17, 2004 | 01:56 PM
Draco's Avatar
Re: .96 G's
the offramp is probably banked as well which will skew readings (allow more G's then possible on a flat surface). I dont know any 270* ramps that arent banked....
Tires will have a much greater affect on lateral G's then suspension changes...
Old Oct 18, 2004 | 02:37 PM
Black Robe's Avatar
Re: .96 G's
Oops, that's actually opposite to what happens. The meter will read less on a banked corner. The springs will compress more, but the side load is reduced, not increased, with banking. The ultimate extreme would be a vehicle turning a corner with 90* banking fast enough to stick to the road with high G readings vertically through the seat and spring, but no side loading...
Old Oct 19, 2004 | 02:04 AM
Draco's Avatar
Re: .96 G's
I disagree... We know a banked corner will allow a car to travel faster before losing grip. this results in a higher centripetal acceleration, which is what the g-meter will measure. the roll magnitude of the car as it travels around the turn will probably be greater then the bank of the turn, so the g-meter should not be skewed significantly as you suggest.
Old Oct 19, 2004 | 02:16 AM
sideways_Into_3rd's Avatar
Re: .96 G's
Also keep in mind that the G meter is no longer level to the ground .. therefore you need to disect the G vector into vertical and horizontal vectors and take the arcTan (or arcSin or arcCos, dont feel like drawing it out now) of the angle of the bank .. grade 11 physics
Old Oct 19, 2004 | 09:57 AM
Black Robe's Avatar
Re: .96 G's
I don't think the Cadillac G-meter cares if the vertical (relative to the car) G load varies at all. The only indication it will give is the resistance to change of its horizontal vector, ie the tire grip/slip with any changes in path from straight ahead. If the banked road surface helps the car turn, the loading in that horizontal vector is less for the same speed, which does allow the car to go faster in the turn but as the higher speed is reached it will still reach the same ultimate horizontal (again, relative to the car) slip limit/G loading. Ah I love this ****...
Old Oct 19, 2004 | 10:19 AM
Re: .96 G's
You guys knock yourselves out. I just know it was FUN.
Old Oct 19, 2004 | 10:26 AM
Black Robe's Avatar
Re: .96 G's
Ya, we're just tryin' to keep up!
BLWNLT1
Apr 20, 2011 07:58 AM
Tricked-Out-Toy
Sep 28, 2008 09:09 AM
NC-LT1
Feb 26, 2005 12:17 AM
NC-LT1
Feb 25, 2005 09:58 PM
SMOKNZ
Jun 19, 2003 09:49 PM
