Pacific Alaska, California, Hawaii, Oregon and Washington
8 hours later I finally got my headers to fit. Sort of...
Old May 24, 2003 | 10:34 PM
Erik's Avatar
Classic Tech Moderator
I got my engine in and the damn drivers side header would not fit. So, thinking that it can't be that hard to do motor mounts I bought a nice set of Energy Suspension motor mounts. Well, it turns out that the nuts for the motor mount bolts are inside the cross member 5 hours later I finally managed to get the nicely rusted lock nuts out, losing a couple of the nuts inside the cross member in the process. With the help of a now destroyed distributor wrench (from hammering it onto slightly too large metric nuts) I was able to get the mounts in, in just an hour and a half. Another hour and a half later I finally managed to wrestle the motor onto both mounts.
My headers fit better, but not quite properly yet, so I'm gonna have to put a torch to the A-arm mount and bash it in a quarter of an inch.
Never again do I want to do f@#$ing motor mounts on a second gen camaro.
It appears that all I have to do now is tighten the harmonic ballancer so it lines up with the other pullies, wire the distributor, wire the starter, install a new fuel pump, get a shiny chrome dipstick , pour oil and coolant, and hook up the carb (hopefully I can figure out how to do that one... I'm pretty much clueless as to where what lines have to go
So close to running! woo hoo!
Old May 25, 2003 | 03:16 AM
bunker's Avatar
Man get that thing on the road, I wanna see what a new motor sounds like, one that runs properly we haven't seen that in awhile around here
Old May 25, 2003 | 04:01 AM
blue 79 Z/28's Avatar
damn you've never seen mine then bunker what a shame, go to the dyno day and you can see my fine piece of nostalgia
Old May 25, 2003 | 04:04 AM
oh and erik, if your having the problem i think your having with those headers, theres a support beam that goes from the crossmember to the frame, its a little pinner looking thing. that needs to be removed to fit in aftermarket long tube headers, you dont need it in, i removed mine, it should say in the instructions on the header if you got ones specifically made for a 2nd gen
Old May 25, 2003 | 04:19 AM
bunker's Avatar
You 2nd Gen guys, I'm going to sleep early today nite nite, its sleepy time.
quick, abandon ship!
C6LS3
Apr 15, 2015 09:50 AM
NewsBot
Mar 27, 2015 06:32 PM
kandied91z
Jan 23, 2015 11:14 AM
squarehead
Nov 21, 2014 08:02 PM
