abs delete
Old Jan 5, 2016 | 03:46 PM
95LT4Z28's Avatar
abs delete
i plan on deleting the abs on my 95 z28. i am not concerned about the plumbing i am concerned about keeping the light off and have read that there may be trouble starting the car. anyone have experience with this?
Old Jan 5, 2016 | 07:54 PM
Re: abs delete
Welcome to CamaroZ28.com!
You will have better luck getting responses if you post questions like this in the correct "tech" forum. Not many people come to "New Member Intro" to answer tech questions.
ABS has nothing to do with whether the engine starts. Unplug the EBCM. Remove the bulb or cut the wire.
Old Jan 6, 2016 | 08:50 AM
95LT4Z28's Avatar
Re: abs delete
new to the site. thanks for the reply and the advice. looking to upgrade my rear. how do you like the strange? any issues with fit? sway bar?
Old Jan 6, 2016 | 04:31 PM
Re: abs delete
Strange held up to 5,000 - 6,000 RPM clutch dumps (McLeod Street Twin) on a very sticky track, back when the car still had the T56. With the TH400 it has a much easier life. Very easy plug-and-play.
I did have a problem when Strange installed a carrier without the machined-in ABS reluctor. Adjustable sensor was there, but no reluctor. But they had me take it to a local shop, which we both agreed on, and sent the replacement carrier, all new bearings, etc to the shop. Fully warranted the shops work.
I wouldn't get the ABS option again. The Strange adjustable sensor had a short life, and I didn't want to replace it.
The stock sway bar hit the LPW cast cover (used to be standard, now it's optional) when the rear squatted. All I had to do was rotate the u-bolt clamps about a 1/2" rearward, problem went away. But I had to notch the clamp to fit over the locator bar on the axle tubes. I think now they send the unit with the u-bolt mounts welded on, in the correct position.
With a Spohn 1-5/16" solid chrome moly bar, and the huge Spohn u-bolt kit that came with the bar, no problems at all. A buddy of mine had a problem with the upper panhard rod brace contacting the rear when it really squatted, took a 1/4" off a small section of the brace and the problem went away. All sort of minor issues.
Old Jan 6, 2016 | 05:37 PM
95LT4Z28's Avatar
Re: abs delete
thanks for the reply. i would love to buy a strange but do not have the 2700 right now. a little reluctant to dump 1500 into the 10 bolt. ( gears , posi , bearings , axles, hd cover and brace kit
bond2
Jan 21, 2016 09:26 PM
blascwil
Jan 5, 2016 08:11 PM
flubyu455
Parts Wanted
Jan 2, 2016 08:14 AM
Codey1989
Dec 28, 2015 07:46 AM
Raylo32
16
Nov 8, 2015 08:53 AM
