97 ss engine specs
97 ss engine specs
My son has a 1997 SS we have looked on-line a lot for specs for this car #1 it seems like every web site has different specs (mostly hp #)
can anyone tell me the true numbers i have read everything from 285-330hp
Re: 97 ss engine specs
Here's a copy and paste of the info from the "4th Gen FAQ":
That may explain the reason for the various HP numbers you have found. 285 HP is the number for a Z28. All SSs are at least 305 HP. None had the 285 HP engine.
4th Generation (1993 - Present)
SS - available as an upgrade to the Z28 model starting in late-1995 (as a 1996 model). The package include a functional ram air hood scoop and reworked exhaust manifolds resulting in 305 HP and 335 ft-lbs of torque. An optional freer flowing exhaust system brings HP to 315 and torque to 342 ft-lbs. In 1998 with the introduction of the LS1 engine, power was boosted to 320HP, and with the optional SLP exhaust power was boosted to 327HP. The stock wheels and tires are replaced with 5-spoke 17" ZR-1 style wheels with 275/40ZR/17 tires. Hurst shifter and Torsen differential were available options. Bilstein shocks, stiffer rate springs/bushings, and a larger front sway bar make up the optional Level-II suspension. The stock spoiler is replaced with sleeker looking one. "SS" badges replace the "Z28" badges on the front fenders and rear passenger bumper. All cars were shipped as stock Z28s to Street Legal Performance (SLP) Engineering where the above modifications were made through 1997. After that, GM made the modifications on its own assembly line.
SS/LT4 - available only in 1997 with all of the standard and optional SS equipment, but the LT1 was replaced by a balanced and blueprinted LT4 engine with 330 HP. Additionally, they got a new stainless steel exhaust system and exhaust manifolds, and a new Bilstein performance suspension set-up. The cars had to be special ordered as 30th Anniversary cars with a 6-speed transmission, and no T-tops or convertible, and they were then sent to SLP for modification. Production was limited to 100 cars.
