1981 z28
Old Feb 11, 2016 | 01:35 AM
robertsz28's Avatar
1981 z28
I just bought a thermomaster chip for my 1981 z28 what will happen if i keep the 195 thermostat in it?
Old Feb 11, 2016 | 08:15 AM
JakeRobb's Avatar
Super Moderator
Re: 1981 z28
I'm not an expert here, but my guess will be that you'll get all the usual benefits, and that your radiator fan (if it's electronic) will run more often than necessary.
Old Feb 11, 2016 | 09:44 AM
Re: 1981 z28
The listing on the Hyertech page indicates is turns the (electric) fans on at 160*F. It also indicates that it is intended to work with a 160* or 180* t'stat.
As Jake points out, your fans will be running all the time, basically fighting the 195* t'stat.
A thermostat only STARTS to open at the rated temperature (195*). It isn't fully open until the coolant reaches about ~20* higher, in your case ~215*F. That's the temp GM wanted it to run at, to minimize emissions and maximize fuel mileage. They weren't really thinking about a few extra HP, running cooler. Your fans will come on at 160*F and there won't be any coolant flowing through the radiator. Engine will reach 195*F, and the t'stat will start to open. Coolant will cool rapidly in the radiator, and the t'stat will start cycling.
In effect, you have not lowered the engine operating temperature very much, and if the chip also advances ignition timing, you may get detonation (knock), or need to upgrade the octane of your fuel.
Not a good idea.
Aug 12, 2018 09:34 AM
gd1996ss
Mar 7, 2016 09:30 PM
poposhad
Jan 17, 2016 10:53 PM
NewsBot
Dec 31, 2015 08:38 AM
greatsave9
Dec 2, 2015 07:39 PM
