True duals?
ed gaunt does it up in westfield, he did dennis's. costs about $800 from the headers back with mufflers and maybe cats, im not sure. but hed be a guy to try, ive used him before, hes awesome!
brian
brian
yes, ed did mine. his number is 413-562-6969. he did an awesome job. i think jayman350 might have some digital pictures from last dyno day of the duals.
it can get expensive depending on how you want it set up and what type of mufflers you are going to use. i used the pitbull atr stainless steel mufflers because they are small and they are quiter than the flowmaster and they fit next to the trunk compartment in the rear of the car. you can go with the bullet mufflers but they will be race car loud!!! then you can always just use dumps.
i used 3inch pipes off the hooker longtubes, into one 4 inch pipe back into 2 3inch pipes to the 3inch mufflers. no cats.
if you want cats you have to figure in on more money $75-$100 more for catco cats or randoms are like $200 each?
it does not rattle or anything. i picked up alot of horsepower from it. i use to have the edelbrock shorty headers.
any more q's let me know. my car is at eds so you can always go look at it and have an idea what it will look and sound like. i might be going out there on staurday if you want to hitch a ride. my number is 617 789 5354. i live in brighton/newton area.
dennis.
dennis.
like i mentioned above it depends on what you want to do. parts will proably cost about the same as if you buought the mufflex y pipe and mufflex race 4inch cat back system.
then you will have to decide if you want cats or not. and then labor to weld everthing together.
not including cats and headers. it will proably be somewhere between 1000-1200. if you include the headers (plus header install) i would say apr $2000.
if you install a kit out of the box
the hooker longtube headers are $562 coated from summit. mufflex cat back is $640 from tbryne the y pipe is $250= $1452 ***not including instalation.
its going to be about the same price but you will have a custom exhaust and it will be dual.
unfortunately to do a good exhaust it is expensive.
i would suggest you call ed and talk with him. like i mentioned my car is at his shop. you can see and hear it.413 562 6969
dennis
dennis
RX Speed Works
Oct 1, 2015 10:19 PM
