Possibly selling Project (95 Z28)
Just gauging interest ... I would want to get $15000 out of this car. Clear title in hand.
1995 Camaro z28 M6 white Ttops... charcoal interior with the red stipes
55k miles on body... fresh paint in engine bay
slight dent in the rear pass. 1/4 panel (looks like someone kicked it)
Car is not running... it will need to be finished ... but here is what you get:
Engine (shortblock is assembled with 0 miles, the rest are in boxes) This was going to be run with a T88 turbo:
HPE 8.5:1 (with 64cc heads) Forged 383ci (Professionally assembled)
LE AFR210 heads/beehivesprings/2.08IV/1.60EV (new)
GTP LT4 stage 3 intake (used)
AS&M monoblade (new)
224/224 cam (new)
Morel lifters (new)
Cloyes double roller (new
Canton oil pan/pickup (used)
Canton Valve covers (new)
A/C Delco new opti (new)
MSD Coil (new)
Cooling:
CSI electric water pump w/ 160 thermostat (used)
B-Cool Radiator with dual spal fans
Exhaust:
SLP Dual Dual exhaust off an LS1 (used)
Edelbrock 1 5/8" shorty headers, no y-pipe (used)
Suspension (all is black):
BMR k-member, front upper and lower control arms (new)
Spohn rear adjustable LCA's, adj. PHR (used and new)
Hal 12 way front/rear shocks with eiback prokit springs (used)
Drivetrain:
Stock T56 tranny (no clutch or flywheel) (used)
B&M Ripper shifter (used)
Hurst Pistol Grip with a button on it (new)
Moser 9" rear with 3.55 gears/detroit locker/31 spline axles with upgraded 1/2 wheel studs and the reaend is powdercoated black (new)
Fuel:
Complete twin 255's intank with 8 AN feed to large Barry Grant fuel filter (12 inches long), then y's into fuel rails where is exits to holley regulator and 6AN return to the tank. The 2nd pump actiuvates off a hobbs switch. All braided lines. I will include 72# injectors as well (everything is used). There is also an alky injection kit (for boosted applications) installed and ready to go...
Brakes:
Stock
Wheels:
Black ZO6 Motorsport wheels -17 x 9.5 and 18 x 10.5 ... (new), but no tires
Interior:
Double gauge pod with elec. fuel pressure gauge and boost gauge
Here are som old pics before it went up onjackstands
You will need to do all the assembly. Its a dreamlist of parts, you just got to finish assembling. I am running out of steam and am debating getting rid of the car. If I dont get what I ask... then i'll keep it. No worries.
224/224 cam (new)
Morel lifters (new)
MSD Coil (new)
Cooling:
Exhaust:
Drivetrain:
Fuel:
Brakes:
Stock
Wheels:
Interior:
Moshbmx1
Jan 20, 2015 03:27 PM
Jan 5, 2015 07:14 PM
