New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
N.E.Dragway Rental
Old Sep 3, 2002 | 04:22 PM
MA WS6's Avatar
Post N.E.Dragway Rental
We are trying to get a bunch of F-body's together for a N.E. Dragway rental. Here are the details.
Date: Wed, Oct 2nd
Cost: $100 per person (to be paid upon arrival).
Entrants: 20 cars max.
Time: Gates open @ 12pm, racing begins @1pm and ends @ 5pm (regular entrance is not used, use side entrance)
Conditions: Track is prepped as if it were a Sat.
Lanes: Only one lane is open.
Tech: Car is tech'd as if it were a Sat.
How to sign up: Call NED (603-679-8001) and tell them you want to sign up for the track rental on Oct 2nd, they will take your name and put it on the list. NED will have a waiting list in case the max number is met. The list is generated on first come first serve basis.
Misc: If you want to stay for the regular Wed night drags you will have to pay the admission fees to stay.
I hope to see you then.
John
99 Red WS6 formula. All options except hurst. Mods= CAGS!,180 T-Stat,HPP3,Whisper lid,Hurst billit plus,All baffles removed,Granatelli MAF, BGRamMod,Borla Cat Back, 2001 slave,master,and clutch. Dyno #s ( Corrected )
324 RWHP @5400 RPM 334 RWTQ @4400 RPM
Best 1/4 mile 13.258 @ 107.93 MPH. 60 FT = 2.132
Old Sep 3, 2002 | 07:02 PM
My84Z's Avatar
Post
if my car is all set by then i would love to be don't count me in.
95 Z28 M6 with slp coated headers,slp 2otl cat back, cross drilled rotors, deleted maf screens,airfoil,slp sub frames, slp 160 thermo., slp skip shift elim.,slp air temp. module, slp cold air intake, Lt4KM, comp cams gold 1.6 rr's,lt4 clutch and pressure, energy supspension tranny mount, flowtech cutout, Taylor 8 mm wires over the valve cover, bf goodrich dr's, new best 12.88 with a 1.97 60'
couple pics: http://community.webshots.com/user/my95z
Old Sep 3, 2002 | 07:08 PM
chevy94c's Avatar
Post
Sounds interesting i am going to see if i can get the day off tommorow.
Vigilante 3200 Stall Converter, LS1 Driveshaft, B&M Supercooler 19,000 GVW, Moroso Cold Air Induction, MAF Translator Plus, LT4 KM, Fan Switch, Jet IAT, Hypertech Power Stat, MSD Coil, NGK TR6 Plugs, Jacobs Wires, Russell Wire Dividers, Scanmaster, 3.23 Gears, SLP Headers w/PBM Coating, Borla Adj Catback, DMH E-Borla, Air Foil, Metco Breather, LT4 Starter, NX System with Gen-X II kit, Nitto drag radials, Hal rear shocks, BMR STB PHR LCA
Old Sep 9, 2002 | 06:59 PM
POLO97Z's Avatar
Post
John,
I'd be interested if you're still doing it.
(I haven't called nedragway yet)
Steve
Arctic White 97Z, A4, Monochrome Hardtop, Motive 3.73's, G2 Girdle,
A4 Rebuild, Shift Kit,Tranny Cooler, Vigilante 3200, Carbon Fiber DS, Moroso CAI, JBA dual cat shorties, stock y-pipe assembly, SLP 2OTL, Taylor over the valve cover wires and looms w/ Taylor plug boot heat shields, 1LE Bellows, Airfoil, LT4KM, HPP+,GMS MAF, 160 TS, G2 Crank Pulley,March Alternator Pulley, Stock Wheels/BFGR DR's.
Bests/same run/2800 stall: 13.014 @ 103.77 (1.804 60'and 8.252 @ 81.96 1/8).
2001 Monte Carlo SS-Black
Old Sep 9, 2002 | 07:41 PM
MA WS6's Avatar
Post
We are still doing it. Just call NED and tell them you want to put your name on the list for October 2nd.
Look foward to seeing you then.
John
Old Sep 24, 2002 | 05:20 AM
MA WS6's Avatar
TTT
John
Old Sep 30, 2002 | 05:59 PM
MA WS6's Avatar
There is a change of plans.
Due to the very warm weather and some car issue's, we have decided to postpone the drag day until Wednesday October 16th.
Sorry for the last minute change.
John
ChrisFrez
Mar 29, 2015 09:43 PM
NewsBot
Mar 27, 2015 06:32 PM
MA WS6
New England Area
May 9, 2003 06:11 PM
