New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
cam and emissions
Old May 17, 2005 | 06:57 PM
steves97z28's Avatar
cam and emissions
can i pass inspection with a decent size cam? my car is obd2. i just dont want to start doing **** then in dec. not be able to get a sticker. i know i can get a sticker but would rather have the car be legit.
Old May 17, 2005 | 09:39 PM
chevy94c's Avatar
Re: cam and emissions
What cam are you looking at? I am sure with LT1 edit you can find someway too pass. I am going to 224/230 .502/.510 on 114 with LE2 heads.
Old May 18, 2005 | 06:29 AM
i dunno, i was thinkin something like the 306, and 4.10's for now, and then le2 or 3 heads at the end of the summer
Old May 18, 2005 | 10:47 AM
RealQuick's Avatar
You can do any size cam. Your car doesnt go on the sniffer, they just scan the ecu to make sure there arent any codes.
Old May 19, 2005 | 09:15 PM
jgeorger's Avatar
The only problem I can think of at this point would be the misfire test. A big cam has a pretty lumpy idle which will be mistaken as the car missing, setting a code and making you fail the obd plug-in test. LT1-Edit for OBD-II lets you adjust the parameters of the misfire test, thus enabling larger cams not to set that code. I would also imagine setting the idle rpm higher would also help.
Tunercat is also poised to come out with 96-97 LT1 software. Supposedly June 6th. I am waiting for this as it is $380 vs $500. I am also not sure if it will have the above mentioned functionality. If you can wait I will let you know. Tunercat is usually pretty good about adding features. Furthermore Tunercat is not vin locked to one pcm.
Old May 19, 2005 | 09:48 PM
My84Z's Avatar
OBD2 can pass inspection no matter what you do to the car as long as you have somone with edit delete anything that could throw codes hence why I pass with my car
Old May 19, 2005 | 10:15 PM
so with my tuned pcm(still have stock one) i could pass even though the air pump and egr has been deleted out? hell if thats the cause im gonna buy me a laptop and some software and go to town.
Old May 20, 2005 | 07:19 AM
My84Z's Avatar
Correct as long as it is edited out and no ses light you pass no matter what unless they crawl under your car and see there is no cats or if a shop knows the car and looks for the smog pump but I have never heard of anyone that does.
Old May 20, 2005 | 09:03 AM
well i have a friend that does inspections and he said he would pass all the visual **** just that he wouldnt **** with the computer. i was under the impression the because my air and egr was deleted it would show it as not ready and i would fail. if thats the case all that **** is coming off asap. i might go by and plug in to his machine and see what it says.
Old May 20, 2005 | 09:08 AM
My84Z's Avatar
As long as it was "deleted" in the pcm you will pass.Also if it was deleted and you still have the egr and what not that could be another reason why your low on power if the egr valve is stuck open or some other dumb thing.
Old May 20, 2005 | 09:13 AM
i dunno, im gonna give him a call today and hook it up to the computer at his work, if it says its all set to pass, its all coming off.
Old May 20, 2005 | 09:14 AM
My84Z's Avatar
Give the place u had the pcm a call and ask if it is deleted cause you won't know until the emmisions and what not is removed
Old May 20, 2005 | 09:18 AM
when ion tuned the pcm he said he deleted the egr and air codes. i have a sheet from him sayin everything that was done with the tune. i just want to double check cause i dont want to take it all of and then come december i get ****ed for not passing.
Old May 20, 2005 | 04:36 PM
jgeorger's Avatar
This is what I thought too. If you disable the tests in LT1-Edit they show as "not ready". Now the question is how many "not ready's" can you have and still pass. People in other states have said 2 or 3 for a 96-97. However, I was told by a station owner here that if you have one "not ready" you won't pass. I am going to test that out because I think here would be the same as other states.
So when I get Tunercat I am going to turn off the egr and air tests and see what happens. Early June.
Old May 21, 2005 | 07:05 PM
Crovax WS-6's Avatar
ive personally seen 3 not readys and a car still pass. but i have also seen 2 not ready and the car fail. I think it matter which components are not ready.
