Zex, and MSD window switch?
Old Jun 27, 2002 | 02:58 PM
93 LT1's Avatar
Post Zex, and MSD window switch?
Guys, can someone explain how you hook up a MSD window switch. I plan on adding one to my Zex installartion in the next month. I would like a little installtion and background info on the switch before I buy it.
Old Jun 27, 2002 | 04:41 PM
n2oTransAmLT1's Avatar
Post
I called MSD and they mailed me the wiring diagram/schmatics in 2 days. The number is 915 855-7123. I have it hooked up to a Zex kit also. Its a great kit, possibly the best. Good luck with it.
`96 TransAm with 125hp Zex kit and tons of bolt ons.
Old Jul 1, 2002 | 03:14 PM
93 LT1's Avatar
Post
Can you tell me just really quick what the switch hooks up to? How does it know what rpm the engine is @?
Old Jul 1, 2002 | 04:09 PM
strokedTA's Avatar
From: Where people don't discriminate about your induction system.
Post
The Tach.
Dave
Old Jul 1, 2002 | 04:19 PM
MichiganSkip's Avatar
Post
Black wire goes to ground,red wire goes to 12volts(when key is in run position),yellow wire hooks into nitrous circuit relay, and white wire hooks into PCM's tach wire or the tach input of an MSD 6 box. You need 2 rpm "pills" one to turn the nitrous on and one to turn it off just before you shift.Remember not to use the window switch to fire the solenoid directly It's only rated for about 1.5 amps and the solenoids draw about 7.5 amps each.
Skip
Michigan Skip's Flamed 95
95Z28, K&N TPIS 150hp NOS & 27mpg!
MSD 6AL, Window switch,Ford SVO 24# injectors,
2.73's (3.42's to come) Edelbrock headers, Flowmaster exhaust
BMR SFC,LCA,STB
Old Jul 3, 2002 | 09:34 PM
93 LT1's Avatar
Wink
OK. Thanks for the info. One more question! How would I wire it then in regards to the apmerage? What way is there around wiring it to something else. I thought hooking it up to the solenoid would turn it on and off? I'm confused.
Old Jul 3, 2002 | 09:55 PM
drop top steve's Avatar
Post
use the window switch to control the relay and the relay controls the solinoid.
Old Jul 4, 2002 | 06:23 AM
Post
93LT1 If I had your e-mail address, I would sent you a diagram of how to wire in a relay.
Skip
BMR SFC,LCA,STB
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
