would putting in a 255lph fuel pump elimanate any danger???
Old Apr 30, 2003 | 02:36 AM
ram air camaro's Avatar
Lightbulb would putting in a 255lph fuel pump elimanate any danger???
i just want to be safe when i run the bottle which i should be getting in a couple of days , would putting a walbro intank fuel pump elimanate any danger or fuel starvation i just want to be very safe when sprayin the stock fuel pump has about 157,000 miles on it, what do you guys think or should i get something else??
Old Apr 30, 2003 | 02:47 AM
Joe Brodman's Avatar
GP Moderator
Sure as hell won't hurt anything.
Spraying internally stock, you can get away w/ a stock fuel pump. BUT, with that many miles, I think a fresh, high volume pump would be a good idea.
Old Apr 30, 2003 | 08:33 AM
94droptopz's Avatar
would you not have to change the fuel (gas) jet on the nitrous system?
Old Apr 30, 2003 | 12:23 PM
thanks joe, i think i'm goiing to get one how hard is the installation?
94droptopz its a wet kit and plan on using up to 150 shot.
Old Apr 30, 2003 | 02:27 PM
94droptopz's Avatar
say the kit says a 150 shot calls for 52 fuel jet at 43.5 psi. if you install a 255lph fuel pump will you not have more pressure now? seems to me like you would have to adjust your fuel jet for the more gas flow?
now im guessing not stating a fact so hopefully someone who has done this will chime in and tell me.
Old Apr 30, 2003 | 02:33 PM
94droptopz's Avatar
now that i think about it i guess the fpr would only allow so much gas to the fuel rail so it wouldnt even matter how big a fuel pump you run as long as its enough to give you 43 psi at wot.
Old Apr 30, 2003 | 06:06 PM
sweet, i'm going to buy it, thanks for your reply, later
Old Apr 30, 2003 | 06:32 PM
stik6shift98's Avatar
it will defintly help out a lot...but with nitrous u are alwaays in danger
Old May 1, 2003 | 04:15 PM
93 LT1's Avatar
That is a misconception. Installing a larger fuel pump, will not make more gas go into the chamber if it doesn't need to. That is why the injectors, computer, and FPR are there. A larger 255lph, will make gas to the injectors happen faster, and larger IF it needs it. Go ahead and get that pump, its quality and is very cheap insurance.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
