Window Switch Wiring Problems
Old Jul 6, 2006 | 07:47 PM
4mulaJoe's Avatar
I've wired window switches before on other cars. I got this MSD window switch for free and cannot get it to work. The basic NX wet kit is wired as seen here MINUS THE FPSS. It just goes straight to the ground.
With the window switch I wired it as follows:
black=ground
red=red wire on relay(confirmed it gets power when system is running)
yellow=white wire on relay
white=white wire on RED PCM HARNESS. Also tried one of the coil wires not knowing which one was negative(no msd box).
Could the window switch be bad? Any way to tell? The kit works great without the window switch.
Old Jul 7, 2006 | 11:57 AM
1SlowFormula's Avatar
Re: Window Switch Wiring Problems
here you go....
http://web.camaross.com/forums/showthread.php?t=406947
Old Jul 7, 2006 | 12:06 PM
4mulaJoe's Avatar
That's how I have it, but no luck.
Old Jul 7, 2006 | 12:44 PM
Oh I must have been mistaken since I though your post said Red PCM wire and the link I showed said the wire was White, I see it now though.
Old Jul 7, 2006 | 01:02 PM
This might be a dumb question, but you do have the little RPM modules in there, and the red and blue loops of wire on the side are still loops and not cut?
Old Jul 7, 2006 | 06:23 PM
4mulaJoe's Avatar
Yes. I have 3000, 5600, and 6200 rpm pills. I've tried a combo of them all. The loops were cut when I got it, but I connected them back together.
warmeck
Feb 2, 2015 12:44 AM
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Nov 20, 2014 06:32 AM
x7x7
Aug 15, 2002 06:49 PM
