window switch settings
Old May 25, 2008 | 10:11 PM
cmzfly93's Avatar
what would you set a nitrous window switch for revlimit is 6600 rpms going to be using mallaroy 685 box and what would you gap plugs at for 200hp shot i have tr6 and about 400 na hp with only 9.3 compression i have them gapped at .035 right now.
also how many degrees retarded for nitrous and what afr on wideband without it
Old May 25, 2008 | 10:17 PM
Chopstix's Avatar
6400 for best ET or 10 RPM before the shift point for longer tranny life
that should be fine
Alot will depend on what the base timing is at...but I would start with 8-10*
Old May 27, 2008 | 02:30 PM
shiznityz28's Avatar
on a 200 shot we would start at base timming - 9 and AF is tricky it should be just a little richer than stock but you will have to read the plug for the whole picture. id say 12.2 would be a good starting point. Id also use a colder plug for a 600hp car try a 9 if it hates it step down. the diff from a 7 to a 9 is not much. we run a 10 on a 225 shot but the et heads like a 7 on the motor thats a 510 rwhp car.
Old May 28, 2008 | 08:54 AM
Ray@NitroDaves's Avatar
Originally Posted by Chopstix
6400 for best ET or 100 RPM before the shift point for longer tranny life
that should be fine
11.5-11.8 is a good starting point for A/F ratio
fixed my typo's
Jan 23, 2015 01:13 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
