window not working need help ASAP
Old Apr 18, 2008 | 06:43 PM
jay_rich's Avatar
OKay i just set up my summit window switch and nos system. I have it set to 3200 ON 5900OFF. BUT at any RPM when it hits WOT it turns on.
this is the window switch (diagram at bottom of page)
http://store.summitracing.com/partde...5&autoview=sku
I followed the wireing off the diagrams.
Okay there is 3 grounds.
Black ground main
purple ground in window
blue ground out of window
I HAVE ALL THREE GROUNDED TO THE CHASSIS. Is this correct?
Yellow is tach signal (tapped into my autometer tach wire)
Red is output Which i tapped into the WOT and SWITCH wires.
Anywone have any ideas I am running the car at the track tomorrow morning.
ALSO for pulses what is this...it says 4 stroke set to 1/2 the number of cylenders so i set it at 4.
Thanks Jay
Old Apr 18, 2008 | 07:32 PM
jay_rich's Avatar
Im starting to think the GROUND IN AND OUT OF WINDOW wires need to be ran to the WOT? Maybe it sends a ground the wot to turn it off?
Jay
Old Apr 18, 2008 | 07:40 PM
MichiganSkip's Avatar
Don't use the blue wire just the purple one to complete the circuit. It looks like the window switch will work (1) to turn on something either side of the window (using the blue wire) or
(2) to turn on something inside the window setting (using the purple wire)
If you have both the blue and purple wires run to ground, that would explain why your nitrous runs anytime at WOT.
Old Apr 18, 2008 | 07:50 PM
jay_rich's Avatar
So would i run the purple wire to the wot switch with my red wire?
Jay
Old Apr 18, 2008 | 08:07 PM
Jay
That depends on whether or not you are running a setup like in the pic you posted or not. How do you have the system wired up? Are you using a relay to fire the solenoids or not? to answer your questin,no you cant connect it to the red wire on the WOT switch but if you aren't running a fpss then you would connect the purple wire to the other side of the WOT switch that the red wire is connected to. The red wire FYI is just power to the box. The way the Window switch works is.... Red supplies power to the "brains" of the window switch. The window switch completes the circuit by a signal ( from your fpss or the WOT switch) to the purple wire, thru a contact that closed at the rpm yo select, to ground thru the black wire on the window switch.
Old Apr 18, 2008 | 08:25 PM
jay_rich's Avatar
I have the complete system wired like above. Ran my solinoids to 87 on the relay. Ran my ignition to the switch in the car then to the WOT. I have #30 on the realy to HOT all times. I have #86 to the WOT and I have 85 ground.
Jay
Old Apr 18, 2008 | 08:31 PM
jay_rich's Avatar
OKay NOW because im an idiot :P. I leave the red from the box hooked to the one side of the WOT.....on the output of the WOT i connect the pruple wire to?
Sorry for all te confussion lol
Jay
Old Apr 18, 2008 | 08:32 PM
Jay
OK ,pull the ground wire off 85 and hook the purple wire to 85. You're not running a fuel pressure safety switch right?
Old Apr 18, 2008 | 08:33 PM
jay_rich's Avatar
Sorry I am not running one YES. So just run the relay ground to the purple.
Jay
Old Apr 18, 2008 | 08:41 PM
Jay
That's ok, wiring is hard to understand sometimes. The Window switch box is what completes the circuit in the relay to enable the relay to energize only when rpm settings are met. You would want to remove the ground wire from 85 and put the purple wire on the 85 terminal. .If you did wire it all up like the picture, then everything else stays the same. Good Luck.
Old Apr 18, 2008 | 08:43 PM
Jay
Yep,
Old Apr 18, 2008 | 08:51 PM
Here's my last wiring project. A Mallory 685 box with relays for nitrous, purge, and heater. I use the 2 step, high speed retard and the window switch function of th 685 box. I wired it all up so that it can be taken out of the car in about 10 minutes. I also have my dynoJet wideband O2 box tucked in under the relays.
I also have a bracket welded on so I can bolt my laptop on too. I got it all tidied up the other day. Doesn't look all that but it's functional.
Old Apr 18, 2008 | 09:17 PM
jay_rich's Avatar
THANKS SOO MUCH! I just went outside and hooked that ground up and it works!! I also moved my fuel tap into the fuel rail.
Hopefully the techs dont say anything about my setup for now.
Jay
warmeck
Feb 2, 2015 12:44 AM
Brake_L8
Jan 20, 2015 09:44 AM
Collector Car
Jan 5, 2015 10:58 AM
The Seer
Nov 20, 2014 06:32 AM
Snoman73
Nov 17, 2014 07:22 PM
