Will it Handle 150HP Wet NOS Shot
Old May 25, 2004 | 06:22 AM
BlueCamaroZ28's Avatar
Question Will it Handle 150HP Wet NOS Shot
My 355 LT1 engine has a CR in excess of 11:1 with TRW flat top pistons and ZZ9 cam.
I am nearly at 400HP flywheel. I have stock fuel pump and stock injectors with thunder racing PCM tuning.
I want to use 150HP shot of nitrous (wet). I am thinking to use plate system from Nitrous Works.
My question is, will my stock injectors and fuel pump be enough for the 150HP NOS. Will I risk running lean. Do I need to knock some timing to avoid knocking. I am using 94 Octane fuel.
Old May 26, 2004 | 08:30 AM
RacinLT1's Avatar
the stock injectors are fine,as long as they arent maxed out for the n/a combo.
running that much power and then wanting to add 150+ with the stock fuel pump is asking for problems. i would definately upgrade the pump,and you probably want to pull 2-4 degree's of timing.
also go right for the nx system,i had the nitrous works plate,and it was OK,but NX is just that much better.
Old May 26, 2004 | 10:39 AM
94camarof1's Avatar
I'd upgrade pump for sure, and injectors just to be safe
68camaroboltz
Oct 5, 2015 11:56 PM
football4life
Oct 4, 2015 07:48 AM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
