Why can't I see my purge?
Old Jan 11, 2006 | 01:33 PM
MetallicTrans96's Avatar
This may be a simple answer but my car has been sitting since November in my garage. I just installed a 90 degree brake fitting with 2 outlets from my purge solenoid.I then ran the lines out the front of my nostrils on my glasstech hood..lol..but anyways when i tried it out i could see the n20 in a white form...it blew all the way to the top of the celing out of both tubes...looked really sweet...then about 30 min later i brought the camera out to take a picture and when i pushed the button all that happend was the loud hissing sound...could not see any white n20....why is this...the garage is only heated from a space heater so it was probably 40-50 degree...kind cold...but can you tell me why this is ....thanks
Old Jan 11, 2006 | 02:17 PM
1SlowFormula's Avatar
Re: Why can't I see my purge?
Sounds like your out of N2O.... Try warming up the bottle, but you may just have used it all playing with the purge. How long did you hold it?
Old Jan 11, 2006 | 07:39 PM
Why would it still hiss so bad then if I was out...just pressure? My bottle was cold when i tried it the first time tho....i dont know...guess i'll wait till summer
Old Jan 12, 2006 | 10:13 AM
andy katzelis's Avatar
1slowformula's right, you're out of dope. You'll be surprised how much "gaseous" nitrous is still in the bottle. The white you saw was the last of the "liquid" nitrous.
You can still use the pressure to test fittings and solenoids for leaks.
Old Jan 12, 2006 | 10:42 AM
"White Knight"'s Avatar
Get a re-fill and then give it a try
Old Jan 12, 2006 | 10:00 PM
AutoRoc's Avatar
It's gone. Refill time.
Old Jan 13, 2006 | 09:05 AM
Thanks...at least i got to see what it looked like
Old Jan 14, 2006 | 09:51 PM
Mikes 1994 z28's Avatar
Your already out? Was the bottle full when you installed everything and purged it? If so, you may want to check your lines for a leak
Old Jan 15, 2006 | 02:30 PM
SPEED750's Avatar
I agree, your out. I have a 10 pounder and I only get a few good uses before the liquid is gone, but the purge will hiss for days.
Old Jan 15, 2006 | 04:14 PM
HeavyChevySS's Avatar
Also...make sure your bottle is sitting in it's brackets with the correct side down !!!
Post up some pics of the finished results...sounds cool !
Old Jan 18, 2006 | 09:47 PM
Ya i have picture but i dont know how to post them....im pretty sure the bottle wasnt even close to full....how do i post picture on this thing...thanks
probably wont have the actually purge pic of it coming out until spring cuz i wont fill the bottle till then...unless i get impatient which will probably happen.
Quickss96
Jan 29, 2016 05:56 PM
350350
14
Aug 11, 2015 12:03 PM
Strick
May 26, 2015 11:41 AM
NXz28
N2O Tech
Jul 16, 2003 07:31 PM
Hawk
N2O Tech
Jan 13, 2003 07:34 PM
