Where to mount Nozzle for NX wet kit
Old Jun 8, 2005 | 09:20 PM
97formulakid's Avatar
Ok heres the deal. I had my nozzle mounted right below my intake elbow (97 Formula) where the donkey dong was located. Tonight I started to install my CSR water pump and realized that I am no longer going to be able to mount it there. Now I was thinking, the sensor that is on the left hand side of the elbow (if your facing the engine with the hood open), that is the air intake temp sensor right??? Could I relocate that to the hole that once housed my nozzle and then put the nozzle in the Air intake temp sensor hole???
Any suggestions or pics would be greatly appreciated. Thanks
Old Jun 9, 2005 | 01:22 AM
chR15's Avatar
Re: Where to mount Nozzle for NX wet kit
Yes, and well, probally. Nozzle should be 5-6in from tb, but using the good ol' search function yielded a couple of people who have done just what you have done. Good luck
Old Jun 9, 2005 | 09:02 AM
Tried searching and really couldn't find anything. If i did put it in the IAC sensor hole, what would I do with the IAC sensor??? would it throw any codes???
Old Jun 9, 2005 | 10:10 AM
chR15's Avatar
Mount it in the old nozzle hole in the donkey hole. If it doesn't reach, you could just tie it to something, or splice in some wire to extend it to the air box for more accurate readings.
Old Jun 9, 2005 | 10:30 AM
Sweet Thats What I Needed To Know. Thanks
Old Jun 11, 2005 | 12:38 PM
scottslt1z28's Avatar
wont putting the sensor int he airbox advance timing????? (which is what you dont want to do when spraying)..............i am under this same delema with my nx wet kit, but i didnt do it that way.
Old Jun 20, 2005 | 06:00 PM
Redbird1993's Avatar
In an article in GM High tECH PERF. They were throwing together a wet kit much like the one I got from Cold Fusion. It uses the duel spray and fuel nozzle. They want you to mount it about 6 to 8 inches in front of the T.B. in the bellows. These guys took a stainless 4" to 3" exhaust reducer and ovaled out the 4" end and it fit the T.B. and the 3" fit the bellows. They mounted the noxxle in the ss reducer for a very solid fit. I am going to try that when I install mine. My Air intake temp sensor is forward of all of this in the aftermarket ramair box.
Old Jun 20, 2005 | 09:22 PM
whatsup's Avatar
http://www.cardomain.com/ride/948336
Click on bottom picture of motor. You can see I put mine oppisite IAC. Drilled hole and it works great.
SpeedJunkee
Apr 23, 2015 09:51 AM
alphaauto
Jan 23, 2015 07:42 AM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
