where to hide the bottle.....?
Re: where to hide the bottle.....?
Put the 2.5lbs bottle under the battery tray in the opposite side of the intake duct. Its a perfect hidding spot. Just hide the lines, and electrical connections...
illegal to have in your car or illegal to use or what? Nitrous isnt illegal unless you live in some hick state. If your insurance finds out that you have it, you will be dropped.
It's not illegal if you hide it correctly like mine !
Don't place it in the spare tire area - - every dumbazz that wants to race for money will LOOK THERE FIRST!
I put my 5lb bottle on opposite side of the Spare Tire well. You know, behind the rear driver side tire. I remove the speaker grill cover to turn the bottle on.
Originally Posted by pennys58
I'm just going to put mine in the backseat, between the two seats. I've got a buddy that does custom fiberglass fabricating and is going to make an arm rest for me.
Here is how I have mine. I don't know if it would give you any ideas or not?
http://www.screamandfly.com/xtrememo...images3/08.jpg
That is perfect! Did you do any "mock" fittings with the rear seat in? I am definately going to lose space with the genx2 kit on. Did you just drill straight down for the blow down tube? Run into any problems? How did you run the s/s line? Great set up...just what I want!
I had the seats in it for a little while I took them out when I put in the roll bar to make up the diffrence in weight plus the fact that no one can sit back there without crawling threw the hatch. I found an old pic with the seats still in. Not a very good pic but you get the idea. I got the brakets from a local muffler shop. They are just hangers. It is a very sturdy setup. You just need to tilt it at the top a bit and let the bottem of the tank ride on the tunnel a tad. The blow down tube was just long enough to poke out the hole in the trans tunnel. If you need any better pics of the brakets etc. Just let me know. Hope this was helpful to you.
http://memimage.cardomain.net/member...419_5_full.jpg
Ditch all of your Hvac stuff and hide it in the dash, theres a good amount of room in there. you may be able to hind one of the little bottles in the area of the passenger air bag, im sure tho
-john
-john
does anyone know what is directly under the hump behind the backseat but before the trunk? wondering if i can have a compartment built in there if it has some clearance.
Your gas tank is in there!
Thanks for the pic...does your nitrous lines run under the car by where the blow down tube is or is it run a different way? Thanks a ton
Under the Seat there is a rubber plug. I cut a hole in it and ran the line threw it.
I was going to take the time to figure out a way of my bottle but i said the hell with it... im just going to mount two 10lb bottles on either down tube on my cage in the back window and leave it at that. it would be a nice view,lol
I believe in NY state it isnt illegal to have in your car but only illegal if its hooked up
-john
-john
