where to hide the bottle.....?
Old Mar 18, 2005 | 07:25 PM
myslowcamaro's Avatar
where to hide the bottle.....? sounds kinky but i want to get a small wet shot hookup. my problem is where to put the bottle. i have t-tops and a cd changer so trunk area is off limits. is the area between the back seat and the trunk ok or bad idea? or any other ideas.
Old Mar 18, 2005 | 07:48 PM
BaddAss93TA's Avatar
Re: where to hide the bottle.....?
put it where your spare tire is.... and get AAA< lol
Old Mar 18, 2005 | 09:02 PM
not a bad idea. too bad it takes 6 hours to respond to a call. at least around here.
Old Mar 18, 2005 | 11:22 PM
DOH... yea that sucks then. but thats the easyest place. once you take teh jack and spare out there is alotta room in there. and no one will ever know... hell they can even look in your trunk, haha
Old Mar 19, 2005 | 11:57 AM
94NDTA's Avatar
Spare tire well is the easiest place to put it. Best part is that there is a rubber plug that can be made into a gromet for your blow down tube. There is plenty of room to run wires/lines inside or outside of the car from this location. It also saves on weight because the tire/jack are removed. Only thing that sucks is that if you don't have a remote opener, it is kinda a pain int the *** to go back and open/close it when you want to use it. Otherwise, no one can see it.
Old Mar 19, 2005 | 02:11 PM
317indy's Avatar
Get a 5lbs bottle and hide it in the engine compartment.
Old Mar 19, 2005 | 04:37 PM
any idea on who might sell that? im all for that. if i cant get that then it looks like bye bye jack and tire, hello can of fix a flat.
Old Mar 20, 2005 | 10:08 AM
funina91ss's Avatar
Where in the world would you put a 5lbs bottle under the hood?
Old Mar 20, 2005 | 06:15 PM
317indy's Avatar
You know on our LT1 body style cars? Well theres the cold air intake side to the drivers side, then on the opposite side you could cut a hole, and fit one right in there..
Old Mar 21, 2005 | 02:29 PM
94Zpower's Avatar
uhmmm ok but where is your Battery?? because thats where mine is.
I can see a 5lb bottle MAYBE going on the drivers if you have a WS6 or SS air box but thats about it.
Old Mar 21, 2005 | 03:36 PM
1SlowFormula's Avatar
even if you moved the battery, then you forgot that the radiator overflow is under there!
Old Mar 21, 2005 | 08:02 PM
pennys58's Avatar
I'm just going to put mine in the backseat, between the two seats. I've got a buddy that does custom fiberglass fabricating and is going to make an arm rest for me.
Old Mar 23, 2005 | 09:18 AM
viperkiller's Avatar
ask him what it would cost for him to make me one. becouse i like to be able to use my trunk space due to the amount of trips i take out of town. and its a hassle to undu the panel each time i want to get to the bottle.
Old Mar 24, 2005 | 09:00 PM
wicked_95z's Avatar
I hid mine in the glove box . Everyone around here puts theirs in the spare tire well. Its getting to be a more popular place to look because everyone is putting it there
Old Mar 24, 2005 | 09:11 PM
roadtrip120's Avatar
You can put four 2.5 lb bottles in the back seat leanback. Just y them all together.
I put my 15lb in the spare tire area
http://memimage.cardomain.net/member...72_20_full.jpg
