When to squirt the juice at launch?
Old Apr 30, 2003 | 03:16 PM
Redbird's Avatar
Arrow When to squirt the juice at launch?
I want to know when most of you real drag racers inject the N2O with an A4? My new converter will flash to 4140 rpm. Is it at this point I add the squeeze, a little after or a little before?
Now remembering when we add N2O BEFORE top stall RPM we are making more torque which will make the converter stall higher. You need 2000-2500 rpm between the stall and shift point.
Sounds like setting the N20 window switch at 4200-6300 would be best for me. ANY OPINIONS??
Old Apr 30, 2003 | 03:52 PM
Twice The Fun's Avatar
play around with it, see how your car reacts, but u should ahve no problem spraying off the line....the rule is dont spray below 3000, i learned the hard way....but since u can stall to 4K plus off the line, flip the switch and drop the throttle!
4200 sounds good, and set it to shut off a lil b4 your shift points.
Old May 1, 2003 | 07:40 PM
KTamez's Avatar
Its a traction issue IMO. I would leave the Window Switch at 3000rpms. So long as you are at a safe RPM level, and can get traction, you can never engage the system "too soon".
Old May 1, 2003 | 08:56 PM
stik6shift00's Avatar
YES.....with out slicks you will slide all over the place....get like 5 second 60' time...haha j/k i would wait a bit
Old May 1, 2003 | 09:41 PM
funina91ss's Avatar
I 2nd that
Old May 1, 2003 | 11:00 PM
AutoRoc's Avatar
sdagvfds
Are you doing a progressive controller Kevin? If so, it would be well worth it to see how the car reacts with a few milliseconds worth of delay on the nitrous hit coming out of the hole. Just to let the suspension plant the tires and THEN have the extra power transfer. I am looking to do the same thing so it doesn't just shock the hell out of the tires by activating the system from a stand-still...ya know brotha? If you're just doing the window switch, I would start by engaging it at the stall rpm. Goodluck testing, hopefully I'll see ya at the track soon.
G-BODYT56
Jan 14, 2022 11:14 PM
Daluchman1974
Sep 11, 2015 06:12 AM
95blkss
Parts Wanted
Aug 17, 2015 09:19 AM
alex5366
Feb 17, 2015 09:07 AM
mark0006
Dec 25, 2014 09:50 PM
