Whats the most nitrous youve sprayed through a single dry nozzle?
For big setups (150-200) is a single nozzle wiht huge jets going to cause any nitrous distibution problems? I would tend to think it wouldnt because nitrous is a gas so it will atomize and distribute more evenly unlike gas
1997 Sebring Silver Camaro SS 6 Speed, Bone Stock
13.52 @ 104.2
***Fastest Bolt On LT1 listing***
Eastern F-Body Association
13.52 @ 104.2
Moving to the Nitrous forum...
Brent Franker * Main Page
94 Vortech Z28 * 96 Z28 SS #1655
4th Gen Appearance Modification Guide
F-Body Install & Fix-It Guides
The NOS fan jet nozzle, used with the Super Powershot solenoid has a flow limitation of about 175-180HP. I think the solenoid is probably the major restriction in that setup though. I run two of those in parallel.... two Super Powershots, two fan jet nozzles, mounted in the outlet of a ram air box, for a system that actually adds 300crankHP. Extensive engine dyno testing showed that there were no nitrous distribution problems with this setup.
http://cjcfo.fbody.com/members/injun...B/N2ONozzl.jpg
http://members.aol.com/InjuneerZZ/im...os/Nitrous.jpg
Sorry you don't feel our replies are usefull here....
Fred
94 Formula A3: 381/TH400/N2O
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
[This message has been edited by Injuneer 94FormM6 (edited June 23, 2002).]
Fred
Detailed Mod's List
A single nozzel will spray a HUGE shot but you need to step up to a -4 line from the noid to the jet. Nos built mine 11" long with a -3 size on one end for the jet and -4 for the noid side.
Next pick a Bigger Cheater niod or a pro shot.
I ran a cheater with a 92 jet/110 octane/36 pound injectors with 70 psi on the rail and 22 total degrees of total timing on champion s59c plugs... nice 10.40ish tune up on a lil 355
RUENUF
Mar 13, 2016 03:37 PM
RX Speed Works
Oct 1, 2015 10:19 PM
