WHat system for a Super VIc and elbow?
Old Jan 21, 2008 | 07:09 PM
FASTFATBOY's Avatar
Heres what I have
Super vic converted to EFI, sheetmetal elbow, monoblade. SLP 85mm maf.
What do I need, a carb type plate system? Like the zex 82221 or the NX with the spraybars on the sides? If the NX plate, can it be jetted for EFI fuel pressure?
OR
The NX MAF system? Do they make one for a 85mm Z06 type MAF?
I like the MAF deal, what is better a straight 200 shot on a progresive controller or a 2 stage 200 shot? 100+100
My intake tract is not straight, I have a LT1 WS6 type box, a 45* coupler, MAF and another 45* coupler into the Monoblade.
David
Old Jan 21, 2008 | 08:28 PM
Boosted_Z28's Avatar
David-Have you considered a plate system that mounts behind the t/b? Nitro Dave makes a kit for the LT-1 that I imagine could be machined for a mono-blade. Also, he made a plate for me that bolts up behind an Accu-fab 90mm t/b. Said they will support up to a 350 shot, but obviously suggests a direct port kit if wanting to go over 200 hp. Just a thought...
Old Jan 21, 2008 | 08:55 PM
FASTFATBOY's Avatar
200 is as big as my ***** are gonna get.
The plate behind the TB will mess with my throttle cable setup. I think.
The NX MAF deal is essentially the same thing?
David
Old Jan 21, 2008 | 09:15 PM
David-Since I'm using an aftermarket t/b, I had my own set of problems to contend with regarding the throttle cable, so I can't comment on what would work for sure, but Nitro Dave's plate includes an extension plate for the throttle cable. Here's a link to a thread that has some pictures/information...may be useful.
http://web.camaross.com/forums/showt...ght=LT-1+plate
Todd
Old Jan 21, 2008 | 10:04 PM
Chopstix's Avatar
this is what I am running
http://www.nitrousoutlet.com/installs/install.asp?id=23
this will give you better distribution and does not affect hood clearence
and it only cost $250...it will handle either low or high pressure
Old Jan 21, 2008 | 10:39 PM
FASTFATBOY's Avatar
No way I am pulling my intake back off...ohhh no.
David
Old Jan 22, 2008 | 11:52 AM
Ray@NitroDaves's Avatar
David
I understand that....in that case I would suggest a carb style plate.
You will get better distribution from spraying at the intake instead of in front of the TB.
Both Zex and NX make a very nice plate.
Here is a link to the NX 4150 flange plate conversions.
http://www.nitrousoutlet.com/catalog...del=52&dept=11
We also carry all of the ZEX and NOS carb plates also
Old Jan 22, 2008 | 02:31 PM
FASTFATBOY's Avatar
Ray NX makes a kit with no spray bars in the middle, they are on the sides.
So what is better a 200 shot on a progressive controller OR a dual stage 200, 100+100?
Give me a price on:
Plate system
Hump mount, and spare tire mount
Bottle warmer
Window switch or progressive controller.
David
Old Jan 22, 2008 | 09:38 PM
Z-RATED94's Avatar
David, forget the bottle warmer, get the Nano system.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BLK1997Z28
May 7, 2015 03:01 PM
lt1matt
Mar 21, 2015 07:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
