what should i gap my ngk tr6 plugs at?????
Old Jul 15, 2002 | 10:01 AM
stik6shift98's Avatar
Post what should i gap my ngk tr6 plugs at?????
i think they are the hgk tr6 anyways...
but what shouldi gap them at im sprayin 100hp
nx wt kit
thanxx
Ran 13.398 with shi*ty stock bald tires havn't run with the nittos yet.
AOL SN: stik6shift98
1998 Camaro Z-28
Old Jul 15, 2002 | 10:19 AM
n2oTransAmLT1's Avatar
Post
I would say around .035 +/- .002. My plugs said they came pregapped at .032 but when I measured them they were really aournd .034-.036, every ground strap seems to be a little different. I have not had a problem since the new plugs on a 125 shot.
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
Old Jul 15, 2002 | 11:40 AM
gb95zconv's Avatar
Post
.038
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Jul 16, 2002 | 05:21 PM
1FastRedZ's Avatar
Post
.030 I had a misfire problem and put new wires and pulled the plugs and regapped to 30 and no more nastey popping out the exhaust and it fills much better. It was probably just the wires but that gap works well IMO.
95 Z28 6 speed
Sprayed with other go-fast parts.
KYWes
Jun 14, 2022 06:52 AM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
Speeds8erM-1
Aug 20, 2002 09:12 PM
