What fuel pump to run with the bottle?
Old Mar 17, 2005 | 11:59 AM
Royce Friesen's Avatar
Question What fuel pump to run with the bottle?
Ok, Ive got a complete NX hitman kit for a carb application. I also have a NOS LT1 plate for the throttle body. Basically all I need to finish up a kit for my LT1 is a fuel pump. What pump do you guys suggest that will fit the bill, but not break the bank? Ive got a stock pump in the tank BTW.
Old Mar 17, 2005 | 07:32 PM
slp223's Avatar
Re: What fuel pump to run with the bottle?
i has an nos in line pump work fine for me.
Old Mar 17, 2005 | 07:53 PM
viperkiller's Avatar
i would check into the walbro 340. i put one in a couple months ago. i'm waiting to put my system on and my stock pump went out and the guy a cmotersports recommended this one. he said it would handle a 250 wet shot no problem, and probly more. it was only $130.
Old Mar 17, 2005 | 10:04 PM
roguedriver's Avatar
The Racetronix for the LT1 with the direct wire is a nice set up. I have it in my setup. Keeps up with my set up nicely. Check them out on the web. It's a direct in-tank swap.
Ken R.
Old Mar 18, 2005 | 12:17 PM
94Zpower's Avatar
I am using the Walbro 255lph high pressure intank pump, works good for me, only $90 from new era performance.
Old Mar 18, 2005 | 02:59 PM
MEAN_SBC's Avatar
The most common pump that is used when upgraded in this application is the Walbro 255, and everyone seems to have great luck with it. The Walbro 340 isn't a bad choice either, and should keep you extremely safe, even with big shots.
Old Mar 18, 2005 | 04:03 PM
DrewHMS97SS's Avatar
wb255 vote
Old Mar 18, 2005 | 07:16 PM
Well, I won't spray more than 100. Maybe 150, but hardly ever.
Old Mar 19, 2005 | 12:14 AM
Racetronix's Avatar
http://www.racetronix.com/Racetronix..._Pump_Kit.html
with or w/o harness.
Thunder Racing carries them.
Old Mar 19, 2005 | 04:21 PM
Derrick Redd's Avatar
I'm running the walbro 255lph also. No fuel issues.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
