what else is needed?
Old Feb 7, 2008 | 08:18 PM
steves97z28's Avatar
This is what I have picked out so far. What else would be needed to safely run a 100-150shot on a low mileage lt1? I would pick up a bottle heater/purge
http://www.dynotunenitrous.com/store/scripts/cart.asp
Old Feb 7, 2008 | 08:33 PM
jerminator96's Avatar
Only you can see your shopping cart buddy, the rest of us have an empty cart.
Old Feb 7, 2008 | 08:40 PM
ok..I had these two items in there
http://www.dynotunenitrous.com/store...p?idproduct=67
and....
http://www.dynotunenitrous.com/store...?idproduct=110
Old Feb 7, 2008 | 08:54 PM
2000GTP's Avatar
The nitrous sticky here should give you a good idea of what accessories you should be running to safely and consistently spray.
Old Feb 8, 2008 | 08:56 AM
Ray@NitroDaves's Avatar
To get the best results from the A/F shut down switch it will also need a wideband O2 sensor. It will work with the factory narrow band but it just isn't as accurate as a wideband.
I suggest running a FPSS and a window switch at minimum with any nitrous kit.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
