Vortech elbow and nx
Old Feb 13, 2003 | 06:22 PM
OffspringZ28's Avatar
will this work? asking because NX has a single nozzle and wont vortech's elbow hinder this with its center divider thing?
Old Feb 14, 2003 | 07:36 AM
strokedTA's Avatar
From: Where people don't discriminate about your induction system.
Won't hurt it at all.
Have fun.
Dave
Old Feb 14, 2003 | 08:13 AM
wont the divider only allow nitrous to go to one side of the block? im still a little paranoid..... i was getting the trick flow one but thats on back order.
Old Feb 14, 2003 | 08:23 AM
strokedTA's Avatar
ok, you have an elbow from a vortech supercharger? Well if so, like I think you mean, then you'll mount the nozzle in that elbow, drill and tap the hole for it. Your nitrous is going to FOG into the intake, it will then be divided by whatever cylinder is in need of fuel. You won't be hitting 1 side of the motor.
Don't worry about it.
If you're really that worried, I'll sell you a direct port fogger set-up! LOL
Dave Brown
Wheels Up Racing (NX Dealer)
Old Feb 14, 2003 | 10:09 AM
rskrause's Avatar
Moderator
I set up two nozzles, one at ~2 o'clock and the other at ~10 o'clock as I was worried about uneven distribution. Probably not necessary though.
Rich Krause
Old Feb 14, 2003 | 12:59 PM
Z28ROC's Avatar
No problems with the Vortech here. www.z28roc.cz28.com/en1.jpg
Old Feb 15, 2003 | 10:52 AM
volZfrk's Avatar
Rich Krause
I was thinking about getting the elbow also. Rich are you running single or dual stage like Z28ROC? Any pics?
By the way, Z28ROC, nice setup!
Mike
Old Feb 15, 2003 | 05:43 PM
chesee48's Avatar
Ahhhhhhhhhh i want a vortech elbow now after seeing that pic...
Where do u guys suggest me finding one? i know Summitt has them...anywhere else cheaper?
Old Feb 16, 2003 | 03:04 AM
Z28ROC's Avatar
Thumbs up
volZfrk,
Thanks.
Old Feb 16, 2003 | 03:20 PM
rskrause's Avatar
Moderator
Mike
Single stage, two nozzles. I was running two 75hp nozzles last year. This year, I am going to try two 100hp nozzles and if it doesn't go fast enough (and doesn't blow up), 150hpx2! With this setup I may stage it. Presently, both nozzles feed off one set of solenoids. Obviously, I will need another set to do two stages.
Rich Krause
Old Feb 16, 2003 | 06:44 PM
volZfrk's Avatar
Cool! I think I'm going to have to do something like that to "trick out" my setup!
Thanks guys!
Mike
RUENUF
Mar 13, 2016 03:37 PM
marlar98
Oct 21, 2015 02:02 PM
football4life
Oct 4, 2015 07:48 AM
Slayer
Aug 17, 2015 03:55 PM
