TNT LS1 F2 kit on a LT1?
Just really depends on how you want the kit on your car a plate setup or a nozzle setup, is the tnt ls1 kit you have now the power ring kit?
would either need to buy a plate from nitrous dave and the lines from the plate to the selanoid and make sure to have the appropriate fitting for the selanoid itself. or find a way to plum the current nozzles in the ls1 kit into your lt1 elbow.
The Plate the comes with the TnT LT1 Kit is basically a spacer with two holes drilled into the top threaded for two nozzles to go threw, which as stated by ray causes issues with the distribution as you you will be shooting the nitrous/fuel to the very back of the intake and bouncing it off there. this does not give even distribution to the cylinders.
Also Dont take the hype of the power gains, TNT is Notorious for underrating there jets, for example on my 94 z i had the TNT F2 Kit with there 100 horse pills in, gained 143 horse 255 torque to the wheels, This was actual wheel horsepower. Do Not Tune based on the calculations for hp by TNT.
anyone can give you the jets for a 150 shot and tell you its the jetting for a 100 shot.
With all that said the plate that nitrous dave offers helps distribute the nitrous/fuel as it should unlike that of the TNT plate.
CARiD
Jan 14, 2015 04:00 AM
CARiD
Dec 26, 2014 04:20 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
