Time to set the record....250+ through a stock shortblock
Old Mar 18, 2004 | 10:07 AM
OBDIICamaro's Avatar
Ok the fogger is complete with the seperate nitrous enrichment fuel cell and pump.
What is the timing I should bump back with
200
250
300
Also I am running a 2 step colder plug right now. Will that be enough?
I just changed the oil with some 20w50 Royal Purple race oil.
Gas will be 100 in the tank and 116 in the cell, everything sound good here?
I am going to start off with the 200 so I can compare numbers to the 200 shot I was doing through my home made dual nozzle kit. Then it will be bumped to 250, if I dont like what I see shes getting the 300!!!
For those that dont know, I have a COMPLETELY STOCK SHORTBLOCK. I love pushing the limits.
Old Mar 18, 2004 | 10:42 AM
NXz28's Avatar
Are you using a dual stage or a single stage to hit those numbers?
Old Mar 18, 2004 | 10:55 AM
Single stage Fogger
Old Mar 18, 2004 | 11:12 AM
NXz28's Avatar
IMO it won't handle too much using a single fogger setup. Do you have anything else done to the motor, head work, cam, bolt ons? On my heads/cam lt1 with a single stage 150shot i almost hit 600ft lb tq to the rear wheels.
I would do a dual stage setup and seperate the stages with about 500rpms. I'm sure a stock short block will easily take a 250shot and maybe even a 300shot...
What kind of fuel pump are you running?
Old Mar 18, 2004 | 11:16 AM
I sprayed 200 through a 2 bit dual nozzle kit I made and at one point was spraying about 170 through a Dry shot, I dont think I will have any problems with this.
Its a Heads, Nitrous cam and every other bolt on possible. I am at this point thinking about a progressiver controller, but I am undecided.
Old Mar 18, 2004 | 11:21 AM
NXz28's Avatar
I'd get a progressive controller or do a dual stage setup.
Old Mar 18, 2004 | 11:28 AM
Ya I havent decided yet on the progressive.
Old Mar 18, 2004 | 03:46 PM
mtxpert's Avatar
Won't be setting a record with a 250 shot.
280 shot already being done on an Impala.....
The Cherry Bomb under new ownership
Mike
Old Mar 18, 2004 | 04:11 PM
NXz28's Avatar
Mike
Was this with a single or dual stage? Rear wheel hp or fly wheel 280hp? Dry or wet kit? Mileage on the motor?
Old Mar 18, 2004 | 04:17 PM
mtxpert's Avatar
http://impalassforum.com/noncgi/ulti...=001144#000000
http://impalassforum.com/noncgi/ulti...=001192#000000
Here's your info...
Mike
Old Mar 18, 2004 | 08:06 PM
What is his engine setup? What heads, Cam, Trans and Converter?
Old Mar 18, 2004 | 10:12 PM
mtxpert's Avatar
You are more than welcome to ask him all the questions you like.
I do not know his exact setup, just wanted to clear the air that a 250 shot was already being run on a stock block LT1.
Mike
Old Mar 19, 2004 | 09:00 AM
Oh if you noticed on the heading I posted 250+ That means 300 baby
Old Mar 19, 2004 | 06:13 PM
capricess's Avatar
locally theres someone that went from 13.9 to 10.80 on n2o with no internal engine mods
Old Mar 20, 2004 | 10:19 AM
n20ta2's Avatar
Please send me pics of the carnage,I love it when people push the limits!
