Thinking about getting N20
Old May 14, 2006 | 02:25 PM
tycosbean's Avatar
I have a thousand to waste and was wondering what to go with. Should I go 3.73s w/ air intake, nitrous, converter, or is there something else I should try to get. I have lt1 edit so I can adjust about anything. I just want to make my car faster. Any suggestions?
Old May 14, 2006 | 03:17 PM
2000GTP's Avatar
Re: Thinking about getting N20
Either of the nitrous supporting vendors, Harris Speed Works or Nitro Dave both offer very good kits. I got my NX wet kit and the GenX2 upgrade package for under a grand so it is a good bang for the buck power adder as you know.
Old May 14, 2006 | 03:34 PM
tycosbean's Avatar
Ive never messed with n20. Is it ok to run like a zex 75 shot on a stock driveline or will I have to change the torqu converter or something similar to that?
Old May 14, 2006 | 03:43 PM
2000GTP's Avatar
Your car will handle a 75 shot with no problems. Alot of people safely spray 100 shot or more. You will not need a converter change with the addition of nitrous. Its a hit or miss whether your stock driveline can handle the extra power.
Old May 15, 2006 | 12:31 AM
Moshbmx1's Avatar
Im running a HarrisSpeedWorks wet kit on my stock 95 Z with the exception of the upgraded igntion and everything else you need to run the nitrous safely. Im spraying newhere from 100-125 depending on what im doing.
Magenta_Hearts
Mar 22, 2015 03:36 PM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
kandied91z
Mar 3, 2015 11:34 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
BAD 97 WS-6
Sep 11, 2002 01:45 AM
