Teflon tape
Old Jul 12, 2002 | 12:54 AM
93TAWicked1's Avatar
Post Teflon tape
Bought a barely used NX kit and was going through the instructions and inventory and it gave multiple warnings on using teflon tape only use the paste. The previous owner used the tape it looks like. Is that going to be a big problem?
93 Purple grey TA, WS6 chrome rims, Firehawk hood, hypercoil spring, kyb AGX's. Hotcam fully ported heads, mac headers etc..., 3200 viglante, rebuilt tranny all the good stuff! 12.69 @105.88, 1.74 60ft with Nitto's
Old Jul 12, 2002 | 08:36 AM
1989gta's Avatar
Post
they suggest using the paste because it dries solid where the tape may leak over time.
Old Jul 12, 2002 | 09:41 AM
drop top steve's Avatar
Post
Tiny silvers of tape can also get in the lines and cause problems with the solinoinds.
Bob,you need to get a line cap so when you remove the bottle to refill (weekly for you I'm sure) you can plug the line end, keeps the carpet fuzz out. NOS claims #1 reason for noid failure is carpet fiber. If your worried about the noids we can take them apart and clean them.
Old Jul 12, 2002 | 10:56 AM
KTamez's Avatar
Post
I still use tape *Shrug Shoulders* works fine, I suppose if you're careful when applying it, though I suppose it does "Decompose" abit over time and heat...
The Line Plug is definetly a good idea, that I see alot of people don't do. I'm fanatical about having a quality filter in the system. Crap in the line is the biggest and most common problem for the solenoid(s).
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
Old Jul 12, 2002 | 11:00 AM
Post
Is the filter that comes with the kit a quality filter?
Old Jul 13, 2002 | 05:05 AM
KTamez's Avatar
Post
Uhm, not really. Its better then some, but even though they come apart I don't know how many I've seen leak after being put back together (Customer Cars), or worse yet, on the initial install when brand new.
They actually make another unit that I've had real good luck with. Somewhat larger and includes a 7" piece of braided hose for install.
Pet Peeve: Those darned NOS Filtered Fittings. them things plug by just looking at em!.
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
surreybrad
Jul 29, 2015 02:55 PM
Jul 10, 2015 02:23 PM
alex5366
Jun 8, 2015 07:52 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
WOT
Sep 1, 2002 11:45 PM
