Teach me about N20
Teach me about N20
Nitrous Oxide...the giggle juice..laughing gas..
I really don't know much about it. I get the concepts of how it works but I've got some questions.
When do/can you use it? In an M6 car, can you launch with it, or use it in a low gear for that matter? What happens when you shift?
What's the difference between wet and dry? How do each differ in how the nitrous goes from bottle to motor? I've read that dry is known for causing fires.
Where do you run the line from the bottle to the motor? When in the bottle, is it a gas or a liquid? Thanks for your time, just a kid trying to learn
-Rippin
-Rippin
use it whenever,with a M6 use a window switch to sytop spraying for shifts. launching with it is the best way IF you have the driveline for it.
wet injects fuel and nitrous at the nozzle,dry uses the injectors to supply fuel. neither differ in the delivery of nitrous from the bottle.
it's a liquid when in the bottle. you either run the line through the interior or under the car.
New To Nitrous Its been very helpful to me.
Cbr02
Aug 24, 2015 07:12 AM
96z
Sep 19, 2002 10:45 PM
