Stock fuel pump and nitrous
Old Aug 17, 2003 | 05:30 PM
cjksflorida's Avatar
Who's still running the stock fuel and also spraying nitrous. I don't really want to change my fuel pump out right now. The pressure stays at or around 40psi through the whole power band and I'm only looking at spraying 75-100 shot occassionally. What does everyone think about this, I'm new to this nitrous thing, so any inputs would be appreciated. Thanks in advance.
Old Aug 17, 2003 | 07:05 PM
SDAKOVIC's Avatar
with that small of a shot you will be fine. but as soon as you try 75 to 100 shot you will want more. the first setting i tried was 75, could hardly feel, then i went to 125, diffently felt that. i only use 175 for the weekends and thats alot of fun.l
Old Aug 17, 2003 | 08:38 PM
So do you use the 175 with a stock pump or do you have an aftermarket pump?
Old Aug 17, 2003 | 09:47 PM
gb95zconv's Avatar
I think at 125 your pushing the limits of the stocker....Ild stop at 100 to be on the safer side.
Old Aug 17, 2003 | 11:53 PM
TMDZ28's Avatar
wha the said.
rilexs man, you will feel the diff. with 75 wet shot. get NX kit and you WILL feel the diff. i know i did.
Old Aug 18, 2003 | 03:39 PM
Derrick Redd's Avatar
I'd stick with a 100 shot max on a stock fuel pump. For piece of mind you could put a fuel pressure safety switch on also. I run a 255lph Walbro intank and have no problems running a 150-175 shot NX.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
HectorM52
Jul 30, 2017 11:46 AM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
