Spraying with stock Ignition?
Old Jan 15, 2003 | 12:17 PM
dabear95's Avatar
I was wondering if anyone out there was spraying with the stock ignition?
Maybe a setup like this?
NX kit, maybe 50-75 shot
Bottle warmer
Window switch
FPSS
1 step colder plug gap at .035
Do you think this is a cheap, but safe way to get started in nitrous?
Then in the future it could be upgraded by adding the following
Good Fuel pump
MSD digital 6 to pull some timing
Remote Bottle opener
150HP jets
Jason
Edit - Type
Old Jan 15, 2003 | 01:01 PM
COMNBYU's Avatar
i started with a 100 shot on a completely stock car. stock pump, plugs, wires, ignition, etc. i sprayed the 100s for a little over a month with zero problems. i put the 150s in about week and a half ago and have sprayed it a few times with no problems.
i think youll be fine like you are, in fact id have the 100s in now. of course you can never be too safe, and thats why you see so many guys buying every single peice of saftey equipment before putting even a 50 shot on their car. but its not nessesary and i know of PLENTY of people running stock LT1s with gas with NO problems.
my car is getting ready to trip 100k, so im gettng ready to do plugs/wires. ill be using the stock type wires and either stock, or one stage colder plugs. havent decided yet.
people who underestimate the craftmanship and strength of a GM small block should not be allowed to own one. (im not standing behind their driveline parts )
Old Jan 15, 2003 | 11:50 PM
chesee48's Avatar
if it were me, i'd probably wait till i had everything that u wanted to get and then do the install...why take the chance ya know?
i have everything sitting, waiting till the spring
Old Jan 16, 2003 | 09:18 AM
justahoe's Avatar
I'm running the same set your talking about minus the window swicth for about a year with no problem. I'm running a 75 shot and am very happy with it, took more then a secon of my 1/4.
Old Jan 16, 2003 | 11:32 AM
dabear95's Avatar
I'm not running that setup yet, I am debating if I want to. I could run that setup in the spring or wait and do heads/cam in the fall/winter.
If I do the nitrous, I could just start on a 396/AFR heads on the side and skip the heads/cam stock shortblock
Jason
Old Jan 16, 2003 | 11:51 AM
Derrick Redd's Avatar
I know a guy running a stock ignition and fuel system spraying a NX 150 shot. He ran 12.04 @ 114 with a 1.8 60ft. spraying 30ft. out. His only other mods are CAI and a cutout. His car is an auto with stock stall and 3.23 gears. IMO you should be fine with a 75-100 shot.
Old Jan 16, 2003 | 01:19 PM
dabear95's Avatar
Thanks guys!
Now I just have to decide if I want to go fast this summer when I flip the switch, or fast all the time the summer after by doing heads/cam on the stock shortblock in the fall...
Decisions, Decisions, Decisions...
Jason
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
