Spraying lots of nitrous- Need help, advice and predictions
Old Feb 7, 2003 | 11:44 AM
  #16
speedmiser's Avatar
Originally posted by Reckless
IMO, and others, it's not a good idea to spray over 150 through the throttle body, but that is your choice. You will risk the chance of fuel puddling in the intake and a backfire, and unequal distribution.
Hmmm... my motors been together for over 4 years and I've went well over 200 through the throttle body. So it's definitely possible to do it safely without experiencing puddling or backfires.
'Course if trey has the bucks to go fast dfi and dry, along with the fuel system to support it, then i'm sure he can also afford some type of direct port injection for the the nitrous.
Old Feb 7, 2003 | 12:02 PM
  #17
speedmiser's Avatar
Originally posted by Mikael
I honestly think that a 3 or 4 stage setup with 50hp per will be better for you, since its somewhat controllable.
Not to seem too f&f style, but a switch on the wheel for each that you can easily reach. 1 stage per gear.
Seems a bit excessive, but i think will end up cheaper. That way if you only do 150, you dont' need a direct port, just 3 nozzles.
4 stages that are activated by hand? Are you joking? I cant imagine trying to operate 3 or 4 momentary buttons while driving. How could you steer or shift? .
Old Feb 7, 2003 | 12:19 PM
  #18
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Auto
4 stage is overkill IMHO-
thats like 4 50 shots or something.
I'm going to stick to my dry shot (shoot a little 75 shot) till i get a DFI system. I still need suspension and a rear which are cramping this years budget. I already have head porting, valves and a valve job to pay for.
and if someone on the street beats me when i have the 75 shot-
more power to them. 550-600hp is a lot to toy with
edit:
i'd never mess with a momentary swtich
4 WOT switches
Old Feb 7, 2003 | 01:02 PM
  #19
speedmiser's Avatar
Make sure you budget for a new tranny if your still running a 4l60e
They dont like big nitrous and strokers - too much torque =
Do you have plans to upgrade your fuel system? Or has that already been done. I dont think the stock lines and rails will support the flow you will require to run a 225+ dry shot on your stroker, even with a larger pump or pumps. Dunno for sure - you may want to ask around.
Also, are your rings gaped for spray?
It may be worth your time to stop over in the advance tech section or PM Injuneer. I beleive he's running a 383 with dfi, a dry setup, and a big shot.
Old Feb 7, 2003 | 01:09 PM
  #20
treyZ28's Avatar
the trans is jacked!
rings are good-
maybe i'll file them when i pull the heads or something
i have a 255 walpro.
Old Feb 7, 2003 | 01:14 PM
  #21
Mikael's Avatar
A 4 stage could use the same WOT and window switch.
And i was thinking the momentary push button's that you push once and they're on, push again and they're off.
I'd also say that DFI is overkill, you really dont need it.
Old Feb 7, 2003 | 01:29 PM
  #22
treyZ28's Avatar
FAST is your tuning GOD
Old Feb 7, 2003 | 02:08 PM
  #23
speedmiser's Avatar
Iv'e yet to see a built 4l60(e) live long with over 700 rwtq. You'll probably be making bout 750 rwtq on a 225 shot, assuming your in the 420-430wrtq range NA. I know there are guys running quick NA combos with 4l60's, but they dont see the kind of torque spikes that big nitrous shots provide.
I'm not questioning the pumps capability, rather the lines/rails abiltiy to flow the volume you'll need.
Old Feb 9, 2003 | 09:47 AM
  #24
BiGEdna's Avatar
Tire
I dunno but i have greatluck wit McCeary( american racers)
there damn good i think for a dirt tire on the street , i dunno i myfriend pulls 1.7's @ orlando on themmm just a though and teher way cheapper than et streets
Eddie
Old Feb 9, 2003 | 10:59 AM
  #25
KTamez's Avatar
OK, Heres the lowdown:
Don't bother with a Dry System unless you are spending the BIG money (Mine was well over $3k) for for a Sequential FAST System with Individual Cylinder tuning. A B2B setup (The Typical $1900-$2000 system) just does not give you enough control. Now believe me when I say that going to a Sequential system opens up a BIG can of worms. I really don't think the Aftermarket EFI system is necessary for you. Thats not to say it isn't better, and you would be better off with it, though I just don't see it being a good Bang for the Buck Item. I'm sure you're not revving this thing over 7k, which is one of the primary reasons many guys go to DFI/FAST
In the end you can get what you want with a Wet system. I don't like progressive controllers, and so I would either use 2 stages, or just have 2 different systems. A Smaller 100hp Single Nozzle System (in front of the TB Type). And a Larger Fogger system just similar to Reckless has shown. Multiple stages are NOT =as simple as they sound, So personally I would just use JUST the Fogger at the track, and the Single Nozzle on the street.
Feel free to give me a shout if you have some questions.
Old Feb 9, 2003 | 11:49 AM
  #26
treyZ28's Avatar
I have access to DFI systems for about $1600
Old Feb 9, 2003 | 11:52 AM
  #27
RacinLT1's Avatar
most $1600 dfi setups are BtoB,not sequential,and like Kurtis said,your setup really doesnt need a dfi setup,2 stage wet and have fun.
Old Feb 9, 2003 | 11:58 AM
  #28
treyZ28's Avatar
its F.A.S.T.
Old Feb 9, 2003 | 12:01 PM
  #29
RacinLT1's Avatar
The basic FAST systems are bank2bank,sequential's are about 2200+
Old Feb 9, 2003 | 12:17 PM
  #30
treyZ28's Avatar
ohh ok... i was a bit confused
How do you like your nitrous controller?
