Sprayed for the first time today....
Old Jun 8, 2004 | 05:00 PM
LSUxBlake's Avatar
was spraying 125, felt AWESOME. I turned the car sideways in second gear when i first hit it, but I straightened it out and it took off. I think I've probably jetted a little too rich, but I'm gonna keep it that way because I need this motor to stay alive. I'll have dyno numbers on it next week.
Old Jun 8, 2004 | 05:10 PM
12Second3rdgen's Avatar
I remember the first time I sprayed. 3rd gear at the track I remember wincing as I pushed the button expecting the worst, then feeling the car pick up and start pulling . Awesome feeling .
Old Jun 10, 2004 | 08:04 PM
HeavyChevySS's Avatar
Ahhhhh, I hear ya !!! Good job with the laughing gassss.
My first time was in an LT1 T/A, felt like the car was kicked in the rear by Godzilla! Friggen awesome !!!! I can't wait till i get the cheater kit installed on my Chevelle!!! Extra 250 HP is gonna be incredible !!!
Old Jun 11, 2004 | 05:44 AM
Amped96's Avatar
I sprayed mine for the first time about a week ago. It is addicting. I noticed a pretty good difference while spraying, but I noticed the biggest difference going back to N/A. Man the car felt so slow all motor after a night of messing around on the nitrous.
Old Jun 11, 2004 | 09:24 AM
GJE94Z28's Avatar
Wink
Love the juice...i'll be trying the 150 shot soon.
Old Jun 11, 2004 | 11:44 AM
Derrick Redd's Avatar
Gotta love the dope.
Old Jun 11, 2004 | 10:31 PM
darkangel95's Avatar
Old Jun 12, 2004 | 12:30 PM
redzsmoked212's Avatar
yeah i can just imagine what n2o feels like on the first time you spray thats why i wanted to ask you guys about it,im gonna get a dry nitrous kit and just do the 100 shot but i wnated to know about the other stuff you need to buy for safety precautions i.e. purge kit and other stuff like that. i know there really is know safe way but there are ways to reduce risks with some other modifications to the nitrous.any help would be great guys thanks
Old Jun 12, 2004 | 12:41 PM
LSUxBlake's Avatar
I don't know about using a dry shot........ why don't you use a wet shot to avoid having to change your injectors? Regardless of what you decide to use, run a RPM window switch, WOT switch, and I'd recommend a fuel pressure safety switch.
Old Jun 12, 2004 | 04:26 PM
GJE94Z28's Avatar
Ditto to the above comment.
Old Jun 15, 2004 | 03:21 PM
i didnt know you had to change the injectors when i read about the dry kits they say pretty much install hook it up and your good to go, i also heard something about spark plugs? anyone know?
Old Jun 15, 2004 | 06:18 PM
LSUxBlake's Avatar
The diff between a dry and wet kit -- Dry kit sprays just nitrous and relies on the fuel injectors to supply all the fuel. A wet kit sprays a mist of nitrous AND fuel, therefore allowing you to run the stock injectors. If you're running a relatively small shot - up to 150, it's also much safer as you tend to not run the risk of going lean. I'd recommend a wet kit, it's just as easy to install, the only extra line is a fuel line coming off your schrader valve, and that literally takes 2 minutes to hook up. You also need to change your spark plugs. You need to go with a colder (2 steps), copper plug such as autolite 103. If you run the stock plug, you run the risk of burning the platinum tips off and scarring your valves.
Klypto
Mar 23, 2016 09:05 AM
Fatdog2
Feb 13, 2015 08:19 PM
David Dorris
Jan 17, 2015 08:10 PM
tds1213
Nov 27, 2014 12:55 PM
